Old 03-13-2004, 03:32 PM   #1
Lobo'74
Lobo'74's Avatar
'67 Ignition Switch Housing
I just bought a '67 chrome ignition switch housing. PO set up the ignition switch as an "outie" instead of the stock "innie". I want it stock looking so I got the switch. Goes on fine, but I obviously need some typs of spacer behind the dash pushing the switch back. As it is, it flops forward out of the instrument panel.... So I had to put it back together as PO had it(for now).
I do not know if ITruck is early or late '67. The ignition switch retainer bezel I got is for the early '67 truck. Are the ignition switch spacers the same for both? I haven't seen a spacer marked "early '67", only late. Does this mean only the late '67's needed the spacer and I bought the wrong part?
As usual, thanks for any information y'all might provide.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 03-13-2004, 08:48 PM   #2
crazy4chevs
crazy4chevs's Avatar
a pic might help (give you more responces), but i think they both take spacers. I believe the one you need is the shorter one.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 03-13-2004, 09:48 PM   #3
pickupman
pickupman's Avatar
the 67 switch spacer is different than the 68-72 spacer. I have not run into a difference between an eary and late 67. I probably have a used one. I can check when I get to the shop tomorrow if interested.
Thanks,Bill
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 03-13-2004, 11:52 PM   #4
Lobo'74
Lobo'74's Avatar
Most definately
Yes, I'm very interested. Thanks for any help. Don't know if you remember me - I got all my window and door rubber replacement from you about a year ago.Sure helps quiet the rattles.
"Truck"
'67 small window
Old 03-15-2004, 05:33 PM   #5
pickupman
pickupman's Avatar
Sorry, I have looked and don't have any left.
Old 03-16-2004, 12:13 PM   #6
Lobo'74
Lobo'74's Avatar
I appreciate your looking for it.
"Truck"
'67 small window
