Old 03-13-2004, 05:54 PM   #1
soonerfan39
66 suspension swap.
Hi,
I was wondering if anyone could tell me if you can swap out the entire front suspension from a 76 half ton to a 66 half ton? I have a 66 short box 1/2 ton pickup and a 76 half ton parts truck. I would like to use the spindles and rotors to get disc brakes, but not sure what I would need to do to accomplish this task. Also can I use the power booster off of the 76? How about the steering box....the 76 is a two wheel drive pickup? Thanks in advance for the help.
Kevin
soonerfan39 is offline   Reply With Quote
Old 03-14-2004, 03:08 AM   #2
soonerfan39
cmon guys!
cmon guys, someone help me out here!
Old 03-14-2004, 09:37 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your good, but you will need to do a little mod to make the steering box work. There is currently a power steering thread around here detailing how to dimple the frame for box clearance.
The crossmember swap has been done gobs of times. It's pretty much a slam dunk, requiring only 2 bolt holes to be slightly enlongated. All of the rest of the bolts line straight up.
I do not know about the brake booster swap.
Old 03-14-2004, 01:25 PM   #4
98L150
///Relaxed Atmosphere
98L150's Avatar
I have doen this
I swapped all my 64 front end outwith all ne updated parts that you are mentioning. The power stearing box reauires a modified brakect to mount it tot he frame. I belwive Brothers or some like that has a bracket you can buy for this. The brake booster will require you to drill some holes to get it to mount. All in all it is a fairly simple swap/ When I did mine I went ahead and added drop spindles and air ride.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
