It followed me home?
headlight question
My low beams dont turn on but when I turn the brights on all four lights come on? I have already checked the wires from the switch to the bulbs and nothing is grounding out, exposed or touching where they shouldnt. Maybe a bad headlight dimmer (floor) switch? or does that sound like the actual headlight switch?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
STILL PLAYS WITH TRUX
Yep id'e say the dimmer sw is at fault.
Right turn Clyde
Have you pulled the plastic connector that goes to the headlight and wires apart to clean them? What setup are you talking about single or dual headlight's? I have the dual headlights and was constantly blowing the low beam. The high beam would still work and every new headlight I put in did the same thing. So I ended up cleaning the contact points by taking the wires out of the plastic connector to clean them better. It fixed my problem right way.
Might want to try that if nothing else works. ![]()
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
