Old 03-13-2004, 09:35 PM   #1
Dave67
Junior Member
Dave67's Avatar
Question rear breaks '67 3/4 ton... HELP
Arg!!!!!!!!
I need some of your expert advice. I know I saw the answer here, but now I can't find it!
let me start with the begining. After my truck sat for the Pennsylvania winter, I noticed while I had it out today that the rear breaks want to lock up too fast. Just stopping from about 25 MPH, so it's not like I'm standing on the pedal. I pulled the driver side drum, and although it was dusty, the shoes aren't bad, (only about 600 miles, and they worked fine last summer!
This leads to question #2:
I can't remember how tight to make the 2 "ring" nuts, the ones that hold the drum on to the rear end, and also, hot tight do I torque the 8 bolts that hold the axel to the drum?
it's a '67 3/4.
Sorry about the long post!
Dave
67 C-20 LWB
56 Nomad--- nope, sold it
75 Stingray
13 Silverado crew cab
08 Trailblazer (wife's)
Pittsburgh, PA
Dave67 is offline   Reply With Quote
Old 03-13-2004, 09:48 PM   #2
jku72
I suspect that your brakes are fine, they likely just need some use to get back to their old selves. I hope someone can better answer your torque questions.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 03-13-2004, 09:52 PM   #3
Dave67
Junior Member
Dave67's Avatar
thanks, jku....
The service manual doesn't even mention this set up, but I knew it at one time.
I guess memory IS the 2nd. thing to go!
(Can't remember the 1st.!)
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 03-13-2004, 10:17 PM   #4
john
member #16
john's Avatar
Heres the bearing adj. from timken
john is offline   Reply With Quote
Old 03-13-2004, 10:52 PM   #5
Dave67
Junior Member
Dave67's Avatar
And thanks John!
I did find the specs in the service manual after my first post.
Lesson learned, never tear into your rear end AFTER a hard day at work!
67 C-20 LWB
75 Stingray
Pittsburgh, PA
