Old 03-13-2004, 11:11 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Talking Another progress report - Project 68 (pics!)
Got alot done this past week!!!
Got the new seats installed. eBay specials out of an 01 or 02 Chevy. I wanted a set of these for the integrated seat belts. Install was simple, just locate and drill. Had to make a short bracket for the outer front holes, but it was easy:
Got the dash cluster together. The truck had just the simple light only dash, no gauges. Bought a complete cluster off of eBay real cheap, cleaned them all up and put on a set of white overlays. I love those! Bought a new bezel, and installed the tach into the whole mess. Found out later that the same tach can be had to match the new gauges. Also got a complete underdash harness out of a gauge truck, cleaned that up and installed. Also robbed a couple of wires from the front light harness from our parts truck to complete the harness swap. All gauges work just fine now. I'll give this tach to Dad for his 70 and get one that matches the gauges later. But for now, I like it!!
Got the engine close to finished last night. Need to flush the radiator and paint it, get another lower radiator hose, wire looms, a few minor things.
Recap of the engine: GM stock 350 crate motor (250-260 HP, something like that.), Comp Cams 268H cam, Performance Products dual-plane intake, Edelbrock 1406 600 cfm carb, HEI w/Mallory coil, stock ram horn exhaust manifolds. 3 speed on the column, 3.73 rear
Still need to do the brakes, install the new rear bumper after I get brackets, and redo the dual exhaust (it only has 2" pipe. Plan on using ceramic coated block huggers, Flowmasters, and 2 1/2" pipe.). Next will be to relocate the gas tank. Have the kit, just need the time!
More to follow in the coming days...........
Can't wait!!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 03-14-2004, 01:05 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Look's like I am gonna be looking for a set of those seat's they are pretty killer looking ...Congrat's on the progress..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-14-2004, 03:24 AM   #3
bigger=better
bigger=better's Avatar
Seat looks awesome dude!
Tell me about the steering wheel.
'68 GMC Sub 4X4 new project
'69 Pontiac GTO 20 year project
Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from.
bigger=better is offline   Reply With Quote
Old 03-14-2004, 11:00 AM   #4
glock35ipsc
It was on the truck when I got it, but I think it is off of a late 80's/early 90's truck. If I recall correctly, most all GM vehicles from ?? to the late 90's use the same size shaft and spline count, so most anything you like that is GM should work.
Bob
Old 03-14-2004, 01:11 PM   #5
krue
Designated A-hole!
krue's Avatar
Looks good! I like the way the seat looks in there.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-14-2004, 03:19 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
Looks great!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-14-2004, 04:43 PM   #7
casey
casey's Avatar
heres how dumb I am I'm expecting to see 68 pictures, well the 4 you posted were awesome, I'm drooling over that motor, lol
casey is offline   Reply With Quote
Old 03-14-2004, 05:00 PM   #8
Joe67
67 is sold
Re: Another progress report - Project 68 (pics!)
Nice work on the mods
I like those seats as well. Do you still have the in-cab fuel tank?
How is the room between the seat and the steering wheel?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-14-2004, 06:32 PM   #9
glock35ipsc
Yeah, the tank is still there, for now. I have a kit coming, but won't do that until this winter. I have every bit as much room as I did with the original bench, if not a small bit more. They couldn't have fit any better!
Bob
