BAD BOW-Silverado XST
Front suspension rebuilding - POR15 pictures
Here is what I did this week. I had previously removed all the old rubber bushings and pressure washed the a-arm assemblies. Then I bead blasted the parts. Since rust will form immediately I used POR-15 all the parts. They only have a single coat. This is my first time using POR15 and I like it. Next time though instead of brushing it on I'm going to spray it on. If you really want a smooth look, it's better to hang the parts and coat them. Anything that drips over will not look good once it dries. Plus it may stick the part to anything the part is laying on!!
Follow this link to the before and after pictures. Anything I can take off the truck is getting PORed. ![]() |
Professional Grade
Next think you know you're gonna be doing a frame off on Bad Bow, lol
![]() How much does that POR15 stuff cost anyways? I'm thinking I'm gonna shoot my underchassis stuff with it when I have my bed pulled off later on this year...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Insert witty comment here
This stuff is not cheap!
POR 15 This info os from their website... POR-15® - PINT Available Colors: Black Clear Gray Semi-Gloss Black Silver Quantity: 0123456789 $21.00 POR-15® - QUART Available Colors: Black Clear Gray Semi-Gloss Black Silver Quantity: 0123456789 $31.00 POR-15® - GALLON Available Colors: Black Clear Gray Semi-Gloss Black Silver Quantity: 0123456789 $95.00 SPECIAL - 4 Quarts of POR-15 (Mixed or One color) $106.00 POR-15® - 5 Gallon Pail Available Colors: Black Clear Gray Semi-Gloss Black Silver Quantity: 0123456789 $425.00
So many trucks, So little time! |
#4 | |
5 day ban, learn to behave.
Looking good G. I have been wanting to do the por-15 thing for a long time. Keep us posted on your experiences w/ it. I didnt know you could get it in all those different colors. Clear?? Thats kinda cool.
mike |
I bought two quarts!! I used about 1/4 of a quart to do all the parts!!! That stuff covers a lot of area. Next time I'll be buying the pint size and spray it on. Unless you have an extremely large job to do. Like the bottom of the bed!!! Yes I plan to POR it now. I like the stuff. I used the high gloss black. Eventually it will dull a little due to the sun. No problem for me since the parts are for the suspension. I may go back and apply the sun protection but that adds to the costs.
5-7 dropped 87 CC Dually
If you get it in any threads you will have to run a tap through them.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
Mudslides 'r my specialty
Looks great.
Is there anything wrong with just using chassis paint instead of the POR 15? I am going to have mine apart in the next few weeks as well. Are you taking it apart just to take it apart, or did you get some new parts?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
#9 | |
Signals in the bumper.
Good stuff. I finished the floorboard of my truck in the gloss black, but too bad its under my carpet so that I cannot see it.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
The POR is like a coating. If you lay a powder coated part next to a properly sprayed POR part , you could probably not tell the difference. Other than the POR is more shiny. I plan to use it in the engine bay, frame and under bed.
The suspension parts in the pictures are from a suburban. I am rebuilding them to save time when I put in the new engine. My truck also has a badly damage lower a-arm. The suburban parts are just replacements. I'll be adding 1.5 drop coils to the front too. Since the coils are powder coated these POR parts will make the whole suspension look nice. For the costs, it's CHEAP!! |
