04-02-2002, 08:13 PM | #1 |
NEED HELP W/ INSTALLING FRONT LOWERING COILS
I BOUGHT SOME 3" FRONT LOWERING COILS FOR MY 69 CHEVY TRUCK. I WOULD LIKE TO KNOW WHAT WOULD BE THE EASIEST WAY TO INSTALL THEM. OR DOES ANYONE HAVE ANY TIPS. THANKS INADVANCE FOR YOUR HELP!
------------------ 72 CHEVY 4X4 BLAZER 69 CHEVY SWB 95 HARLEY DAVIDSON NOSTALGIA
68 CHEVY SWB 95 HARLEY DAVIDSON NOSTALGIA 68 CAMARO CONV 65 CHEVELLE CONV 39 CHEVY CABOVER |
04-02-2002, 09:03 PM | #2 |
The only real way to do it is seperate the lower ball joint with a jack under the control arm and SLOWLY lower the jack until the spring comes out then in the reverse order put your spring in and jack it back up and put the ball joint nut back on and cotterpin. Check the ball joints while your in there. Its not fun to break on on the road.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-02-2002, 09:20 PM | #3 |
They are another way. Jack up the truck put it on jackstands remove wheel put jack under a-arm remove the two U-bolts on the lower control arm shaft also the bolt on the bottom of shock and slowly lower the jack remove old spring and install new.
------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
