Old 03-14-2004, 05:53 PM   #1
ocbaud
Garage Queen Material
brake pedel makes stuff act weird???
okay, now that my guages are working again, anytime i press on the brake pedal, its like its sucking the power out of it. the parking brake light goes really dim and my voltmeter gets really low.
when i let off the brake, it goes back to normal
ocbaud is offline   Reply With Quote
Old 03-14-2004, 05:59 PM   #2
Russell
Professional Grade
Russell's Avatar
Sounds like a short on your brake switch... Pull the access panel off thats under the steering column and pull wires until you figure it out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-14-2004, 06:00 PM   #3
Destructo
or just disconnect or replace your brake switch, maybe it has a poor ground?
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-14-2004, 07:40 PM   #4
1FaastC10
1FaastC10's Avatar
its a given that your truck is not running. you may want to just hold off on replacing anything until your engine is in and running. may just be an issue of a low battery. when you've got it running, the alternator may very well solve the problem by supplying more voltage.
1FaastC10 is offline   Reply With Quote
Old 03-14-2004, 07:59 PM   #5
ocbaud
i've got it hooked up to a charger rightnow, suppling a full 12volts.
it is the brake switch though, everytime i let off of the switch, the power is drained, but it comes back when i push the switch back in
Old 03-14-2004, 11:41 PM   #6
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Check the brake lamps as well. A short in the sockets could cause a drain also. I agree with 1fastC10, hold off on it till you get the truck running. I don't know what size charger you are using but a small 10 amp charger will drop substantial voltage with a current draw such as the brake lights. Try turning on the headlights and see if the same thing happens.
NeCrOmAnCeR is offline   Reply With Quote
Old 03-14-2004, 11:42 PM   #7
ocbaud
headlights work fine. it only happens with the brake switch
Old 03-15-2004, 12:16 AM   #8
NeCrOmAnCeR
Also check the cab grounds (for dash electrics), make sure the mounting points are nice and clean.
Old 03-15-2004, 02:24 AM   #9
ocbaud
okay, it does drain it with the headlights... and anything else electrical. it drains the power when the brake lights, headlights, dashlights, blower motor, etc. comes on
