Hope someone can help me out. I have a 83 Blazer fullsize 4X4 350 700R4. The other day I was driving home and my truck started to vibrate only when I let off the gas It's not bad while I am giving it gas. It feels like the tranny because while it's doing it if I put it in neutral it stops. A place to start looking or an answer would be greatly appreciated. Thanks folks
STILL PLAYS WITH TRUX
Sound's like the U-Joint's are going south.
Or Have you lifted the truck? If so the pinion angle may be out of spec's and will cause a bad vibration. |
No lift on the truck but thanks for the u-joint tip I will check that out
BAD BOW-Silverado XST
Check the transmission mount too. Motor mount.
I also say U-joints.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
