ran out of money
in a week or 2 i should be ready to put my enigine and trans back into my truck. the thing is i am converting to a 700r4 from my 3 speed sag. i would like to remove my clutch pedel. but i cant figure out how it comes off and the easiest way to remove the spring without breaking something or hurting anyone.
Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
Designated A-hole!
From what I understand, messing with that spring is a good way to lose a finger or worse. Somebody on here got hurt pretty bad trying to do it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
huh ???
It would be eaiser to work on the petals out of the truck. To remove them you will need to drop the steering column and unbolt a few bolts that hold the brake booster on. I'll try to take a pic tomorrow of the petals out of the truck so you can see what it looks like...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
ran out of money
i have a set of pedels out of the truck... but i have like 4 rivits holding mine onto the firewall and didnt feel like drilling them out. if i take the setup out i am just going to put the otherone in..... but i thought it would be easier to just take it apart in the truck.
Thanks for all the help Rat
Firefighter
Why would you change out the pedals with another set???? Standard and auto pedal setups are the EXACT same thing!!! The only difference is is that the clutch pedal has been removed by undoing the spring, the rod clamp and by sliding the rod out of the housing.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
its all about the +6 inches
How butch you wanna be? You could use the 'ole hot wrench.
I thought the pedals were different. Isn't the brake pedal wider with an automatic?
Dan |
Nope, not untill 73.
It's a catastrophic success.
![]() Join Date: Jan 2003
Its been a while, but you unhook linkage theres a clamp on the rod unhook spring with vise grips and slide the cluch pedal and rod out of the center of the brake
Firefighter
What he said!!^^^^^^
That being the case, gas axe for mine! Thanks, Dan
ran out of money
i knew they were the same but i got the auto set up for free so why wouldnt i take it? thanks for the reply's hopefully this weekend i can get it out.
Thanks Rat
#13 |
![]() Join Date: Aug 2001
Bowtie:
BLACK N BLUE IS RIGHT ... IT TAKES ALL OF ABOUT 10 MINUTES TO REMOVE THE CLUTCH PEDAL. WHY ANYONE WOULD CUT ONE OUT WITH EITHER A SAW OR A TORCH IS BEYOND ME. ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 03-15-2004 at 01:16 PM. |
#14 | |
BEER-Vacation in a can...
There is an indention in the cab behind the insulation that the top spring mount fits in to slide it out. You will have to fold back the insulation to find it, but once you do, it takes about 5 min to get out. Other then that, its really simple to unbolt and remove.
Kurt 03' Trailblazer 69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik 2000 Yamaha V-Star 1100 Custom For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics |
#15 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Let's remove a little mystery from this one:
Step 1: remove bolt and nut Step 2: pry arm off of shaft Step 3: push shaft and pedal to the left out of bushings DONE! Total time should be less than 15 minutes, including removing and replacing instrument cluster.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 03-15-2004 at 01:25 PM. |
#16 |
More Cowbell....
Oh yeah....thanks for the visual aide. I am in the process myself. That helps a ton.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#17 |
More Cowbell....
#18 |
ran out of money
thanks for the picture and everything.... lots of help.
Just one more question.... how do i get that spring off? or do i even have to take it off? in your picture i didnt see a spring Thanks a lot Rat
#19 |
I grabbed mine with dikes and pulled it and it popped off. It's not a man killer spring, just a little attention getter spring.
#20 | |
2008 Buick Enclave(wifes new non wrecked) 1996 Jeep Cherokee 2002 2500HD 6.0L (traded) 1998 Jeep Grand Cherokee(wifes/wrecked) 1977 DJ5 postal jeep(mmm lots of fun) 1988 Toyota 2wd p/u(DD, blewup 199,000) 1991 Toyota 2ed p/u (sry just cant break these things) 1997 XR70 Honda 1991 Z50(FOR SALE) 1972 Z50 Honda 1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end". |
#21 |
excellent! i will be doing this to mine soon also.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
#22 | |
#23 | |
huh ???
Chuck
#24 |
Was that spelled COMEfortable shoes on purpose?
#25 |
"Trucks with Class"
![]() Join Date: Jul 2000
Cut it off and go
A 3" or 4" die grinder makes a nice clean cut right up by the shaft...no fires like the torch. Why wouldn't you want to cut it? It is not worth anything to keep.
