Old 03-15-2004, 01:14 PM   #1
shortymac83
hmm...
shortymac83's Avatar
Question about hoods.
On my 67, the hood appears to have (at one point) been glued or epoxied to the bracing. How exactly were these attached together? Anyone have any good and easy tech tips for getting them BACK together?
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 03-15-2004, 01:30 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I expect what you are describing is the padding that was inserted between hood sheetmetal and braces. I've observed that time coupled with excessive heat will melt this material and give it the appearence you describe. New padding can be purchased, or you can leave it "as is"
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-15-2004, 01:53 PM   #3
shortymac83
hmm...
well, it does get over 100 for a few weeks in the summer here, and who knows if the thing has been overheated or what. What it honestly looks like is that someone ran a bead of black silicone on either sides of the hood braces. Is that what you're thinking of? Also, do you know where I could get those pads?
Old 03-15-2004, 02:00 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
The hood and braces were designed so that there was a gap between them. This gap was then filled with pads to prevent the hood from wobbling when going over bumps. So, there should be a gap designed into your hood. As to what it's filled with after 35 years is anybody's guess but I've seen where the pads do get melted making it appear to be epoxy.
You can get replacement pads at any of the vendors listed on the lefthand side of this page .
Since you are a mid-westerner, GMCPauls in IN may be your best bet.
Old 03-15-2004, 02:17 PM   #5
shortymac83
hmm...
Thanks!
