03-15-2004, 09:30 PM | #1 |
can u use a low hump cab as a 4x4?
I am rebuilding a 69 swb 4x4. The cab i have is the old 2x4 type with a low hump. Can i use this as it sits (knowing i have to cut a hole for tx case shifter) or do i have to cut out the entire hump and use a 4x4 hump in it's place.
any help woild be appeciated. thanks |
03-15-2004, 09:33 PM | #2 | |
Bloo
i think you can get by with it-- but you have to use a 2" body lift
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
03-15-2004, 09:34 PM | #3 |
The low hump cab will definitely work on your 4x4.
I would suggest cutting out the low hump and installing the high hump, though. Changing the transmission/transfer case is a lot easier with a removable hump. Jim |
03-15-2004, 09:35 PM | #4 |
Resident Curmudgeon
It is very simple to cut the floor out and bolt in a hump. A hump should not be too hard to find. You won't have clearance without doing this.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-15-2004, 09:49 PM | #5 |
Let me tell you from expierance. If you plan to have any body lift at all, go with the low hump. If you have an automatic tranny go with low hump. This is alot easier than extending your shifters. My host is down right now but when it comes back up I will post pictures of what Im talking about.
Catfish |
03-15-2004, 09:53 PM | #6 |
Jeff,
We have a 72 4x4 with the low hump cab, no lift, stock cab mounts and it clears. We bought it that way, but we are going to cut out the hump asap. Installing or removing the transmission/transfer case in a low hump cab is a dangereous nightmare. Jim |
03-15-2004, 09:56 PM | #7 | |
Resident Curmudgeon
03-15-2004, 09:57 PM | #8 |
i have a 2.5 inch susp. lift right now with a possible 4- 6 inch lift a few years down the road (when i move into a house with a taller garage door...lol)
1 ] will this make a difference? 2 ] if i did a floor shifter (for my 700r4) would there be any complications with that and the tx case shifter on the floor side by side? (i am not sure i will do a floor shifter, i just am curious) thanks again to all |
03-15-2004, 10:02 PM | #9 |
This is in my 67. After cutting the hump down as low as possible I only have 4" of the t-case shifter sticking out. There is also a long and a short t-case shifter from the factory depending on the tranny. I have the long one.
03-16-2004, 04:36 AM | #10 |
I have a low hump, a body lift and the shifter is lengthened about 3 inches.
03-16-2004, 12:31 PM | #11 |
I don't mean to hi-jack this thread..........However, this raises an interesting question. I have a low hump cab and plan on putting a muncie 4spd in my truck soon, can I get away with just cutting a hole for the shifter or does the floor have to be clearanced for the top of the trans?
03-16-2004, 05:07 PM | #12 |
user # 2756
I just cut the hump out of a 2wd cab that I put on my 4wd chassis w/ sm465 and np205. If you have the high hump it's real easy to drill and bolt on after cutting the hole. I'll take some pics when it quits raining.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-16-2004, 08:19 PM | #13 |
user # 2756
hump pics
1
03-16-2004, 08:19 PM | #14 |
user # 2756
2
2
I took the tc shifter off when I swapped cabs, but you can see where it goes.
03-18-2004, 01:49 PM | #15 |
ttt
