Old 03-15-2004, 10:57 PM   #1
ghetocrewzer
ghetocrewzer's Avatar
Front suspension
Found out today that my Suburban has 3/4 ton lower control arms and spindles. Had the lowers clean, sanded, and smoothed and cheked the new balljoints, they fell through the hole. Got the 3/4 ton balljoints and they wouldn't go in my CPP dropped spindles. Truck came factory w/ disk brakes so I just figured it was 1/2 ton. Everything else I got fit fine so I went and found some 1/2 ton lowers and started over. Another day behind, but maybe tomorrow I can paint the arms and other pieces(body color Saffron Metallic) and put it together Wednesday. Then I can finally let the air out the bags and hit the ground. Wish me luck.
ghetocrewzer is offline   Reply With Quote
Old 03-26-2004, 09:07 PM   #2
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
good luck!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 03-27-2004, 12:00 AM   #3
mikesz
mikesz's Avatar
http://www.earlyclassic.com/techarti...ar2004pg1.html
Why give up those heavy duty balljoints and tie rods?
mike
mikesz is offline   Reply With Quote
Old 04-23-2004, 11:23 AM   #4
72sub
My C1500 has 3/4 ton upper and lower control arms. It also has 3/4 ton tie rod ends. I'm pretty sure it's factory, maybe they ran out of 1/2 ton stuff.
72sub is offline   Reply With Quote
