No negative camber, yet body still drops when adding weight...
Someone tell me if this is logical thinking...
So, on the passenger side of my truck, the front fenderlip is lower than the drivers side. Also, when my two 250lb buddies get in the passenger side, the fender drops down about another 1"-1½". But when the fender drops drastically like that, the tire's camber doesn't change. If it was the SPRING that was compressing, wouldn't the camber on the tire change aswell? Therefore my thinking is that is must be the cab/body mounts that are squishing, allowing the cab/body on that side to drop. |
Under construction!
I doubt the body mounts are being compressed that much.
2001 Silverado bagged on 22's. *Sold* |
#3 | |
5-7 dropped 87 CC Dually
Could be that the frame is rusted between the bushings.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
#5 | |
Under construction!
You say the fender height goes down 1-1.5"...??? My PST body mounts are roughly 1.5-2" tall. There is no way 500lbs will compress the mounts to almost nothing, IMO. Despite being original and worn out. Besides, the springs support that 500lbs, not the body mounts.
Tim, did you measure the frame with your friends in and out of the truck.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#8 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: No negative camber, yet body still drops when adding weight...
AND BTW, it is your spring that is compressing, the whole cab would have to flex if just ONE cab mount was bad.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#9 | |
your bushings could still be bad, but i think chris hit it. you are lucky to find a truck where the fenders are all the same height. if i remember correctly there was a post about center of wheel to fender lip distance. if i remember correctly nobody had perfect measurements... i was damn close.. one side was like 3/4" lower than all others. if all cab mounts are good, i wouldnt worry about it too much... its an old truck.
Put your frame up on jack stands to eliminate the suspension from consideration. Measure your fender heights. Then have your friends get in and remeasure.
This should give you a much more objective idea of your cab mount compression. I am also highly doubtful that you could be seeing that kind of compression in your cab mounts. -dch |
Like Captkaos said, you shouldn't see any camber change by an inch or so of travel. Get under your truck, look at the body mounts. Your rubber mounts won't give that much. They would disinigrate (spelling???) before they would give like that. Besides, you would hear the cab banging around on the frame mouns as the front bushings are only bout an inch tall. Look at the cab and frame mounts and see if they are solid. Then look at the front a-arms and have someone push it up and down. You should see it move.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
