Old 03-15-2004, 11:29 PM   #1
jram1484
jram1484's Avatar
Lightbulb need a 4:56 rear end
Hey guys I am kinda new at all this. But I picked me up an 87 Chevy that was in the works of being rebuilt. The only problem is that the front and rear gears are different. There are 4:56 in the front and 3:42 in the rear. I have asked around and since it is a toy truck I would like to go with the 4:56. I am sitting on 45" tires. SO if any one has a rear end with 4:56 gears in it please let me know. I am in Louisiana. Thanks
jram1484 is offline   Reply With Quote
Old 03-16-2004, 12:45 AM   #2
drink2mny
drink2mny's Avatar
WHat type of rear is it??
1/2 ton or 3/4 or 1 ton..
might be cheaper to get gears
With 45" tires I would hope you have a 14boltFF..
Support The Board
drink2mny is offline   Reply With Quote
Old 03-16-2004, 12:59 AM   #3
Destructo
I bet he meant 35", you probably won't find a factory 4.56 rearend with a 1/2 ton, you might find it with a 3/4 ton axle though. But you may just end up having to find an axle that had aftermarket gears put in, or just have your rear-end re-geared.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-16-2004, 07:57 PM   #4
wildwood
wildwood's Avatar
Check out www.completeoffroad.com. Got my 4.56 gears for 12 bolt for around $200.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 03-16-2004, 10:26 PM   #5
jram1484
jram1484's Avatar
Well I will tell you what I do know about it. It is a 1/2 to truck with a 10 bolt diff and it has 3:42 gears in it. No I meant 45" tires. They are huge!!!! I am assuming that it is a GM rearend. This truck was thrown together and I am finding that the guy didn't know what he was doing. So will I be able to put a 3/4 ton axle with 4:56 gears in it on the truck or do I have to change the front end out. Thanks for the replies!
Old 03-16-2004, 10:59 PM   #6
drink2mny
drink2mny's Avatar
Well With those big of tires I would look to put 14 bolt full floater in the rear and look for a set of 4.56..
14 bolts are a dime a dozen in junkyards..But mainly come with 3.73 and 4.10's..So you would still need to get gears..
As for the front it probably is a 10bolt also and I would bet money wouldn't hold up to a couple of times of hard offroad..
you coud go a couple ways, upgrade the outers to 8 lug 3/4ton..
get a dana 44 3/4..
Or the better way to go would be get a Dana 60..
This is just my opinions..
If money is an issue.. the cheapest way would be buy a new set of gears and keep the 10bolt..
If not 14bolt with 4.56's which would be 8 lug so to macth you would need the 3/4 outers for your front 10 bolt unless you don't mind haveing 6 lug on the front and 8 on the back..
I would love to see a picture of the tires..
I have heard of 49's but not 45's...
Support The Board
Old 03-17-2004, 09:59 AM   #7
jram1484
jram1484's Avatar
Thanks for the info.... I will try to borrow a camera and get you some pics to look at. Thanks.
Ramsey
85' K10/77' K20
Its not what you know. Its WHO you know.
Old 03-17-2004, 01:12 PM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I would say you need a 5 something series with tires that tall. 4:56 won't be enough. I need 4:56 and I only have 38's.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 03-19-2004, 12:04 AM   #9
redneck_motorsports
redneck_motorsports's Avatar
4:56 is not enough gear for those tires unless you have a wicked motor making a pile of torq. If you have that then the 10 bolt and even a D44 will bust in a hurry and your back to where you are now. You can find 14bolt ff fairly easily and is one of the toughest rears you can run but they will only accomidate up to a 5:13 gear. hope this helps,
Catfish
I have alot of stuff, some of it is here
redneck_motorsports is offline   Reply With Quote
Old 03-22-2004, 04:00 AM   #10
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Originally posted by jram1484
It is a 1/2 ton truck with a 10 bolt diff and it has 3:42 gears in it. No I meant 45" tires.
WOW! Even if you are running just a stock 350 mtr, That's like using a 3/4" drive ratchet with a 3' cheater pipe on a 1/4" drive socket!
Those weak axles don't stand a chance, no matter how good of parts you put in them.
jeffspower is offline   Reply With Quote
Old 03-22-2004, 10:59 AM   #11
jram1484
jram1484's Avatar
So, am I doing the right thing in going with a 456 or higher gear ratio???? I am still learning all this gear ratio stuff. So thanks for all the comments and suggestions.
Ramsey
85' K10/77' K20
Old 03-22-2004, 11:41 AM   #12
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Yes. if you are getting like 38's, get a 4:56. 44's would need like a 5:??. Get it?
Old 03-22-2004, 11:46 AM   #13
jram1484
jram1484's Avatar
Thanks for the info!!!!!
Ramsey
85' K10/77' K20
Old 03-24-2004, 02:26 PM   #14
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
What are you going to use this truck for?
Mostly show and putting around town?
If you are going to be romping it through the mud then listen to the other responces and put a Dana 60 in front and a GM-Corporate 14 bolt full floater in the rear.
With heavy use you will need these rears and its alot easier to install them when there not buried in 3 feet of mud
If your not going to put a ton of power to it (like 400hp) I do think that 4:56 gears are aval. in the 3/4 ton GM 12 bolt, eaton and dana rears. I know for sure that the GM-Corporate full floater was aval. with a 4:57 and that is a good rear.
Did this help?
Edited for more info and spelling
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
