5-7 dropped 87 CC Dually
Flip kit+sway bar?
Just ordered my flip kit from Macs springs. Will I be able to keep the rear sway bar?
I rather be in my 77 Sanger Picklefork Jet Hydro! |
ocbaud, has both....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
It followed me home?
yep it will work. I have both too
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Sweet. Will I have to do any mods? Kinda want to know what I'm getting into before I start wrestling that Dana70 around.
Garage Queen Material
i had to install mine under the axle
http://www.ocbaud.com/misc.html if i were to of installed it above the axle, like it is suppsed to be stock, it would bottom out all the time |
But this is a 1 ton. It bolts to the bottom of the leaf spring plate factory. Think I should keep the factory leaf sring plate on instead of the one that comes with the kit?
ah, well now that i know its a 1ton!
![]() i dont know about it exactly. you may end up having to buy a aftermarket bar if there isnt a place to mount the stock on. |
Professional Grade
and if that happens, you have a potential buyer of that 1 ton rear sway bar
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Russell, If I don't get it to work I'll let you know.
Mudslides 'r my specialty
I was just wondering the same thing.
I just ordered a flip kit from macspring as well. ![]()
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
