Old 03-16-2004, 02:30 AM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
How much horsePower??
How much HP will i get out of a sbc 350 w/ .60 bore, headers, edlebrock preformer intake and carb w/ electric fan, any guesses?? thanks sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-16-2004, 04:57 AM   #2
PR454SS
PR454SS's Avatar
cam and head info and compression ratio are what is really needed to get a good answer
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 03-16-2004, 11:13 AM   #3
bigjimzlll
bigjimzlll's Avatar
figuring a stock 350 is around 200(real HP) the mods you post will give around 30HP increase....the 8 CI will give 4.5HP...around 235HP as a guess
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-16-2004, 12:13 PM   #4
shortymac83
hmm...
shortymac83's Avatar
I"m going to guess that, assuming your compression is over 9:1 and you have a decent cam, you might be pushing 200 HP to the rear. If your compression is 9.5 or 10:1, you're looking at a bit more than that, and if it's the stock 8 or 8.5:1 like some years had, try about 180 RWHP or less...
We really need more info, and if it's the stock compression and cam, tell us the year so we can get an idea of what you're running.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
