Old 03-16-2004, 03:40 AM   #1
Budweis
Geared for Collision
Budweis's Avatar
JIMs70GMC read this
hey jim im interested in those 4 wheels you have . please post here if you still got. still throwing around ideas but they may be what i need.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 03-16-2004, 05:17 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
still got them, They are heavy and it looks like fed-ex is the way to go, about $10 a wheel standard ground. I'd like $25 each plus shipping. They are american racing white wagon wheels.
Just read your other thread these are 15" wheels and you will have to grind the calipers and backing plate for them to fit a 3/4 ton front end.
I'll mock fit a fender on my 71 w/ 35s and no lift to give you an idea on lift/ tire size/back spacing. Give me a day to do this.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-16-2004, 07:34 PM   #3
Budweis
Budweis's Avatar
how much grinding would have to be done? will this weaken them or increase the chances of cracks? mostly my truck gonna be offroad as using to drive through 500 acres land but it will ocassionally see a 200 mile highway trip possibly. if anyone has a pick of the grinding that has to be done please post so i can decide what want to do. thanks for the fast reply jim and price sounds ok if i decide to go with.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 03-16-2004, 08:34 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Someone posted pics, I'd say in the past 6 weeks on the main forum (67-72) can't remember who it was. I was going to do it to my 71, but was concerned about the material removed, I found some 16.5x9.75 w/ 35s very cheap and put those on instead. If you don't air down then not having the safety bead is not a concern with the 16.5" rims. I believe Beast383 grinded his calipers.
Old 03-22-2004, 04:11 AM   #5
Budweis
Budweis's Avatar
thanks for the info jim, i wasnt aware of the grinding so i think ill go ahead and pass on the wheels sorry for trouble. i finally think ive deciding on running 16x10 wheels now just need to figure out the optimal back spacing.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 03-23-2004, 07:30 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Most rims are in the 3.5 to 4" backspacing range. I had both and the difference is not noticable. You definetly don't want more than 4". I've seen 2.75" available, but that's not enough in my opinion and the tire would really hangout up front, people run them on rigs that have had the calipers grinded on. Now on the back they'll have the rear track with the front. Good luck!
