![]() Join Date: Nov 2000
I am a phone call away from ordering me some 15" Torque Thrust II's. I just want to make sure I get the right size tires. Right now I have 15x10 rallys with 275/60/15's out back and it fills out the fenders well, but they are a tad too tall for my tastes. On front I have 15x8's-235/60/15's, and they are alright, it could use a size bigger perhaps, but I'd appreciate any pics/advice Also I have 2.5" spindles out front with a 4" drop out back. Thanks in advance!!!
Anyone???-Cmon guys!!!
Are ya selling your rally's? 5 or 6 lug?
Thanks Ron
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
put some 245/60s up front and 265/60s out back. a tad bigger in the front and a tad smaller in the back.
'67 c10 350/th350 |
71 DELUX
tires
Your set-up sounds pretty close to mine. I have the 235/60/15's up front, but do not like them. I currently have 255/50/15's on the rear and want to move them up front with either 275/60/15 out back or 295/50/15's (295's preferred).
I guess the backspacing on your wheels may make a difference. Right now I have 15x8's all around, but have the 15x10's in the garage, ready to mount to some tires. What kind of 275's you got there???? |
I would run a 29550R15 O.D. 26.62" which is the same diameter within a fraction as a 24560R15. O.D. 26.58"
Wiseass secured himself a BAN
255-65-15 here
4 the same are you insane?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
I have bfg pro-comps, which I don't like. They have lot's of thread, but they do have some signs of dry-rot inside the threads. They are 5-lug. I will probably sell them for the best offer. They are painted yellow.
I have the newer thicker lugs on my truck from the 90's chevy trucks in order to use the center caps with the plastic lugs. Am I going to have to order the wheels for a 90's chevy or just the lugs??? Thanks for all input...
Should I go with 15x8's all around with the same size tire, or go with 7's up front with smaller tires? Anyone have any pics of a torque thrust setup with 8's all around?
I have 275/60/15 all around. They look great.........I think so!
1971 CHEVY CUSTOM 10 DELUXE |
#13 |
I run 295/50/15 rear 26.61 tall and 235/60/15 in front 26.1" tall, Wheels are TorkThrust II rears 10x15 and front 8.5 x 15. Was running BFG's Thought I'd try a set of Firestone Indy's
#14 |
alot of people run 295/50/15's all the way around, which look really good.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#15 |
Back from the Dead
Heres a 275/60/15 out back and 235/60/15 up front, hope this helps...fills them fenders real good
The only Carb that matters to me is the one under my hood! Salem, Oregon |
#16 |
i love summertime
275 60 15s all the way around here too
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
#17 |
In street trim, 275/60/15 rear and 255/60/15 front. 2/3 drop
![]() At the track, same fronts with 27/12.5/15 ![]() ![]() ![]() I am currently in the process of building a narrowed 9", four link, coilovers and will be doing a mini tub in order to fit 14.5's inside the fenders and will probably end up with Torque Thrusts. ![]()
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#18 |
Black 72 Chevy
I got four 15x8 rims and tire size are 295/50/15.
#19 |
Thanks for all the pics and info guys!
Bowtie67: Do you have any pics of your setup? Thanks I might just stay with the 275/60/15's in the back and just drop it some more, and go with 235's up front. Does anyone have more pics of the 295/50 out back with a lower drop? |
