Old 03-16-2004, 02:24 PM   #1
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Removing Voltage Reg.
I'm needing a little help.
I'm trying to take off my voltage regulator and it's putting up a fight. It looks like the bolts holding it on are retained by rubber bushings or something and it just spins and doesn't un-thread. I wanted to ask for some advice before I put too much leverage on it. I want to take it apart, rewire it, and hook the 2 wire alt up to the old wires to make it look stock.
As always, thanks.
Ro
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-16-2004, 02:39 PM   #2
71Chev
71Chev's Avatar
There are nuts on those 3 little bolts. The nut is on the front side of the rad support
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 03-16-2004, 02:41 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I had to get violent with mine and pull it through the radiator support and then get the nuts off.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-16-2004, 02:55 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I took a pair of needle nose and ripped the rubber off on the grill-side of the radiator support. There is a nut under all of that rubber bushing. I didn't have any problems with the ripping the bushing apart either.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-16-2004, 04:26 PM   #5
Long Knight
I'll give taking the rubber bushing off a shot. Has anyone taken out the regulator stuff and rewired one of these before? I plan on wiring the F terminal to 3, and 2 to 4. Anyone see any problems with this?
Long Knight
Old 02-23-2012, 09:00 PM   #6
lmac1210
lmac1210's Avatar
Re: Removing Voltage Reg.
I ripped two of my dried out rubber bushings as well. Anyone know where I can get replacements?
lmac1210 is offline   Reply With Quote
Old 02-23-2012, 10:13 PM   #7
turp mcspray
turp mcspray's Avatar
Any resto supplier will have them. Your local hardware store should carry them as well. They are called "well nuts".
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-23-2012, 10:31 PM   #8
463
463's Avatar
http://www.google.ca/imgres?q=gm+ext...1t:429,r:0,s:0
Trueman
463 is offline   Reply With Quote
Old 02-23-2012, 10:43 PM   #9
463
463's Avatar
here it is http://67-72chevytrucks.com/vboard/s...d.php?t=507565
Trueman
