Old 03-16-2004, 03:15 PM   #1
A.P.
Black 72 Chevy
A.P.'s Avatar
Pitman arm and tie rod end
Hi to all.
I will be replacing the pitman arm and the tie rod end inner driver side today. Does any body have any tips before I start.
A.P.
A.P. is offline   Reply With Quote
Old 03-16-2004, 03:19 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
If your pitman arm does like mine did and seperates then you will need two forks to get it off And count the threads or turns on the tie rod to make sure you get the new one close. Good Luck!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-16-2004, 03:39 PM   #3
A.P.
Black 72 Chevy
A.P.'s Avatar
A.P.
72 Chevy, SWB, 350engine, TH400
Old 03-16-2004, 05:17 PM   #4
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Take a peice of masking tape and mark the thread of the old tie rod end before you remove it from the sleeve....or count threads...then match it up to the new one and tape that too....thats about it.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-16-2004, 05:28 PM   #5
COBALT
COBALT's Avatar
Use a pitman puller to get it off the steering box. Clean up that end nut, and be prepared to torque the hell out of it when you put it back on. I think the Haynes book has you torque it above 230 ft-lbs if I'm not mistaken. You might want to check.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-16-2004, 06:42 PM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
Guys thanks for the info. but I'm having a hard time removing the pitman arm from the steering box. I got a loaner tool from autozone, a pitman arm wedger but its not working. Is there another tool that I can use?
Old 03-16-2004, 06:46 PM   #7
COBALT
COBALT's Avatar
Like I just said: A Pitman Puller.
Seattle, WA.
Old 03-16-2004, 06:48 PM   #8
A.P.
Black 72 Chevy
A.P.'s Avatar
COBALT
Where can a get one?
A.P.
Old 03-16-2004, 06:50 PM   #9
A.P.
Black 72 Chevy
A.P.'s Avatar
COBALT
I found one. Thanks.
A.P.
Old 03-16-2004, 06:52 PM   #10
COBALT
COBALT's Avatar
Glad you found one. I got mine from Sears a few years ago.
Seattle, WA.
Old 03-17-2004, 04:12 AM   #11
A.P.
Black 72 Chevy
A.P.'s Avatar
Thanks for all your help. Success, I was able to replace all the parts without any problems once I got the right tool. Damn everything is nice and tight. Next project is installing the sway bar.
A.P.
Old 03-17-2004, 04:17 AM   #12
A.P.
Black 72 Chevy
A.P.'s Avatar
Here is a pic of the sway bar.
