Old 03-16-2004, 03:29 PM   #1
72superBB
72superBB's Avatar
quick tranny question.
My th400 looks like it is leaking where the gear shifter goes into the tranny. Is there a o-ring in there? If there is, how do I change that out? DO I have to drop the tranny pan or what?
Thanks guys.
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 03-16-2004, 04:02 PM   #2
72superBB
72superBB's Avatar
ttt
1990 Chevy SWB
Old 03-16-2004, 04:51 PM   #3
Woody
the bad news is yes you have to remove the pan, then the valve body before the shift lever shaft can be removed from the inside. Then you have a small seal (like a grease seal behind the wheel bearings) that you have to pull out from the outside with a hook or something. Then use a small socket to seat the new seal.
Might as well change fluid, filter, pan gasket, the O rings on the modulator & speedo cable, & install a shift kit(if you haven't yet) while you are in there.
Be REAL CAREFUL not to lose the little balls above the valve body.
Woody is offline   Reply With Quote
