Old 03-16-2004, 06:33 PM   #1
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
WTB: Complete V8 Throttle Linkage
We are converting out I6/3-sp. manual to a 350/700R4 and we need the complete throttle setup from pedal to carburetor for our '70 Chevy. Hopefully I can find someone nearby (92860 - So. Cal.) to save on shipping $$$.
Thanks!
Stepsides 4Ever is offline   Reply With Quote
Old 03-16-2004, 08:56 PM   #2
67sss
67sss's Avatar
linkage
so that would be the rod type rather than the cable, correct?
67sss is offline   Reply With Quote
Old 03-17-2004, 03:56 AM   #3
Stepsides 4Ever
Errr...well, I dunno. Is there a cable version as well as the rod type?
I have the rod type with the existing I6 setup. I was thinking of retro-fitting a later model cable type if it wasn't too much of a job, but someone suggested that I try to locate an NOS V8 setup, so I thought I'd explore that avenue as well.
Old 03-17-2004, 07:23 AM   #4
ZOOMY
cable
The '72's have a cable throttle. A little safer with respect to throttle bind & no pedal studs required in the floor. The pedal hangs on a bracket. Somebody here will have one for sale reasonably priced.
ZOOMY is offline   Reply With Quote
Old 03-17-2004, 09:35 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The firewall area where the pedal is is very different between the 72 cable type and the earlier rod type. It's very easy just to make a longer rod for the V8 swap and keep your existing rod type pedal. It only takes a couple of minutes to do it.
Old 03-17-2004, 05:45 PM   #6
67sss
67sss's Avatar
throttle
the first type is the rod type, which you probably allready have on your truck. All you need to do is lengthen the rod to the carb.
The 2nd is the cable type, which you probably don't have, unless someone changed cabs.
Old 03-17-2004, 05:47 PM   #7
67sss
67sss's Avatar
2
Old 03-17-2004, 05:52 PM   #8
Stepsides 4Ever
67sss
THANK YOU!!! A picture is worth many thousand words!
GREAT pictures! And thanks for the advice!
