03-16-2004, 11:20 PM | #1 |
Beep! Beep!
Brake Booster Color?
does anyone have any recommendations on the color that i should make the brake booster. i have a red truck with a flat black firewall and gloss black fender wells.
thanks for any responses 72afr
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
03-16-2004, 11:51 PM | #2 |
Try spinnin 4 rear tars
I vote black
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
03-17-2004, 12:26 AM | #3 |
I bought a nickle cad kit from eastwood, it looks crappy, not the new look like a brand new booster, i vote flat black or cast iron
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
03-17-2004, 12:31 AM | #4 |
Beep! Beep!
thanks, i forgot about the master cylinder, any ideas?
03-17-2004, 12:33 AM | #5 |
we paint ours cast iron as well
03-17-2004, 12:44 AM | #6 |
Beep! Beep!
thanks, sounds like ill go with cast iron
03-17-2004, 03:38 AM | #7 |
Delco Morraine boosters were cadmium plated from factory and Bendix units were painted black. MC's of course were cast iron.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
03-17-2004, 08:42 AM | #8 |
What's the best way to clean them before painting.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
03-17-2004, 12:07 PM | #9 |
Beep! Beep!
i second that question
03-17-2004, 12:20 PM | #10 |
I taped up all the ports then blasted it with glass beads. Leaves a pefect base for primer and paint.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
03-18-2004, 02:28 AM | #11 |
we put a wire brush on an angle grinder
