![]() Join Date: Nov 2002
surface rust on cam/springs
these were in the boxes but left in the bed of a truck I have, can these be cleaned, dipped or whatever to be as good as new. Also here's the # on the cam, N E body tell me what it's suppse to be for?
Thanks SSH 320 NC |
68cst_ss490
try soaking the valve springs in diesel that might help. As for the cam polish it with some crocus cloth
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
I've heard that camshafts and crankshafts will bend if layed flat like that for long. They should be stood on end. Any truth to this???
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
ran out of money
sweet 72: you might be right but if you ever go into a speed shop they have them laying down. i think just like heads if it lays on a cold surface then you should stand them up.
Modify everything, leave nothing alone!~ ![]() ![]() |
CAM
Any idea on what the cam and springs would be for? I went to Cranes site and couldn't find anything to match the #'s on the boxes or the grind # of the cam. Maybe I missed something on their site.
