Old 03-17-2004, 02:26 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Exhaust manifolds
I bought a new set of Exhaust manifolds a few years back and finally went to put them on. I am putting an engine in my project truck and the parts truck has turned out to be just crap everywhere.
My new manifolds turn back at a 45 degree angle and the old ones went straight down. Which is correct for a 4x4, or does it matter? My guess would be the old ones came out of a station wagon or something just as foul.
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 03-17-2004, 03:07 AM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I'm not sure because I have seen both on 4x4's
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-17-2004, 03:23 AM   #3
1969 GMC
1969 GMC's Avatar
im pretty sure that 4x4's used the straight down ramhorns. i would go check for you, but my truck is buried under 8" of snow that we got in the surprise storm last night! brr
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-17-2004, 06:52 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Straight down on the 4x4s. But it did change sometime in the mid 70s to 80s as my 85 K5 had one straight down and one back at a 45 degree angle w/ a heat riser valve.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-17-2004, 11:31 AM   #5
danho
Pesemistic Optimist
danho's Avatar
Hey Scrub, if they're going on your 72 K20 they both dump straight down.
Dan.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress.
1999 Yukon Denali- Wife's ride, hands off.
danho is offline   Reply With Quote
