Old 03-17-2004, 02:30 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
How to convet to 4 core radiator
My radiator setup is for a weenie little radiator and I want to put a four core (or is full core?) in. I need to get bigger mounting saddles and larger rubber gromets (or what ever y'all call them).
Can I buy them, or do I just scrounge some up. They aren't easy to find.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 03-17-2004, 02:56 AM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes you can buy them, I got my set from LMC, but I think that most vendors on the board have them also.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-17-2004, 03:00 AM   #3
Scrub
Scrub's Avatar
Great, Thanks.
Scrub
Old 03-17-2004, 03:03 AM   #4
Firefighter
Any time!!!!
Yellville, Ar. USA
Old 03-17-2004, 04:32 AM   #5
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
Correct me if I'm wrong here, but just looking at my weenie little 2-row radiator, it looks like the radiator supports are on the tank, not the core itself. The extra two rows look like it will fill out the dead space between the tank and the existing 2-rows...IF the tanks are the same size from the 2-row to the 4-row.
Stepsides 4Ever is offline   Reply With Quote
Old 03-17-2004, 08:31 AM   #6
Blue Beard
Blue Beard's Avatar
You'll need both upper and lower brackets...
And the channel where the bottom ones mount has to be either cut and bent or just bent.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-17-2004, 08:38 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
2 and 3 core use the same brackets. The four core has bigger (longer) brackets.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-17-2004, 11:00 AM   #8
71swb4x4
71swb4x4's Avatar
Didn't AC trucks come with 4 core? So you could try to scrounge the brackets from an AC truck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-17-2004, 11:24 AM   #9
danho
Pesemistic Optimist
danho's Avatar
I just went from a 3 core to a 4 core and didn't have to change anything, it was a direct bolt in.
Dan.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress.
1999 Yukon Denali- Wife's ride, hands off.
danho is offline   Reply With Quote
Old 03-17-2004, 01:35 PM   #10
Firefighter
danho, you must be lucky because all of them I have seen with 3 core the brackets are too small for the 4 core and there is no way it would fit unless a person did some serious modification to the brackets. The new ones from LMC weren't that expensive and they fit just fine, also if I bought a new 4 core I would want to have new rubber bushings instead of old wore out ones.
Yellville, Ar. USA
Old 03-17-2004, 01:41 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I went from 3 core to 4 core and had to change all 4 brackets and rubber pads. I bought mine from pickupsnw (only a few miles from me) but just about every vendor sells them. There are a few sets on e-bay right now.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-19-2004, 06:02 PM   #12
Stepsides 4Ever
Just picked up a new 4-row radiator from Radiator Express and...yup...gotta have larger upper and lower brackets. The 4-row is about an inch or so wider in the mounting area than the 2-row. It is a physically larger radiator in the tank area.
Also, I can see the lip across the bottom that will probably need to be removed that Blue Beard mentioned...looks like the radiator core will be sitting on top of it if you don't.
Old 03-19-2004, 06:15 PM   #13
bpmcgee
bpmcgee's Avatar
When I converted to a four core, I just used a pair of channel locks to bend the bottom support flat in the areas of the core support. Worked great.
Brian
bpmcgee is offline   Reply With Quote
Old 03-19-2004, 06:27 PM   #14
Stepsides 4Ever
Good to know...we're pulling the front end off this weekend to begin the changeover...
Old 03-19-2004, 07:30 PM   #15
Chris_T
When I did mine (maybe two years ago?) both the brackets and the rubber bumpers were still available and cheaper from GM.
Chris_T is offline   Reply With Quote
Old 03-19-2004, 08:16 PM   #16
bouncytruck
SKINNY TIRES RULE!
Yup, that's what I did.
I think the truck shop where I bought them just picked them up at the local chevy dealer and then added some $.
bouncytruck 1972 K5
