Old 04-02-2002, 08:38 PM   #1
shortbed70
shortbed70's Avatar
Post charging problem
I have a problem with batteries going dead. I just put a new alt. on but I think the wiring under the hood is screwed up. I need to know how the charging systems wires are run,colors and directions. I've looked in the chiltons but they just tell colors. I need routing also. If I jump start the truck it runs fine It's just not charging the battery. The truck is equipt with 350 2barrel.
[This message has been edited by shortbed70 (edited April 02, 2002).]
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-02-2002, 08:47 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Post
Do you have access to a voltmeter? You should see around 13 or 14 volts on the battery terminals with it running. If not, your alternator is not working or like you said the wires are bad. Check the alternator ouput terminal(red) to ground with it running. Should be the same 13 or 14 volts. If its there and not at the battery, you have wiring probs.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer New project
1995 K1500 Sub(Mommas car)
1989 VW Golf(Beater)
Will be the daughters car if she will pay her insurance! Ha!
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-02-2002, 08:52 PM   #3
Andy4639
Old member
Andy4639's Avatar
Lightbulb
If you have a volt meter, put it on dc, then red to positive, black to negative, crank truck and check what the reading is. It should be at least 13.5 or 14 volts. If it is anything less it ant charging. It's the voltage regulator and not the alternator in less you have swap it for a later one. If you have the right voltage it could be something drawing it down. How long does it take to kill the battery, couple of hrs.,days. Hope this helps.
Andy
71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-02-2002, 09:02 PM   #4
primer67
primer67's Avatar
Post
I feel ya brother. I have the same problem as you do. I am going to do this to stop it.
1. you have to consider what you want out of your truck, do you want to make a rod or a resto?
If you want to make a rod, you only need a few wires. headlights are a must!
there are only about ten dif. wires that you need. The battery ground, the pos. wire to the starter, the starter to coil/hei the power to wiring harness, and a few accessory wires to run the inside compartment/taillights/tach etc.
the PO probable had a connection for every accessory possible, and probably burned a few together in the process of owning it.
I checked under my hood today, and I found a wire, for the dual electric cooling fans that I run and found a bare wire touching the frame, grounding it out, draining the battery. so get in there, and clear out all of the garbage, wrap plastic heatshielding around the wires, screw the wires to the inner fenderwells with wire brackets. about 4 hours aught to do it.
good luck! -- also if you need diagrams, try factory shop manuals. they are a little less vague.
primer67 is offline   Reply With Quote
Old 04-02-2002, 09:03 PM   #5
primer67
primer67's Avatar
Post
hey andy, where is the stock location of the voltage regulator on a '67 c-10?
Old 04-02-2002, 09:06 PM   #6
shortbed70
shortbed70's Avatar
Post
I would like to know where the regulator is on a 70
Troy
Big Red Dog build
Old 04-02-2002, 09:20 PM   #7
wild4wheels
wild4wheels's Avatar
Post
shortbed, I had the same problem on my Panel, check for proper ground. I think mine runs from the battery to the alt. bracket, and then from the alt bracket to the frame.
Good Luck-I hate working on electricity
Wild
'02 Impreza 2.5ts
'94 Altima - For Sale-$2500
67 Panel
'88 Isuzu P/U - For Sale-needs motor work-$400
'79 Bonneville(Greenie) (wifes Grandparents car new!) - For Sale-$200
Parting Out:
'72 Burb
'85 BMW 528e
WTB
C-30 1 ton dually
car trailer
burb rear quarters!
Dave aka "Wild"
Current truck
"Ida Mae" 71 K5 Blazer
Former Trucks
"Loretta" 71 Longbed (AZ)
"Tanya" 69 Stepside (AZ)
"Ferdinand" 71 Longhorn (SD)
"Patches" 67 Panel (IA/ KY)
"Rosita" 68 C30 (KY)
Instagram @Wildforwheels @k5_klub @c10university
Profile pic provided by Jeff Sundance
wild4wheels is offline   Reply With Quote
Old 04-02-2002, 09:37 PM   #8
Gordo
Talking
Regulator should be found on the inside of the radiator support on the drivers side. This might be a good time to change over to the newer style alternator with the built in regulator.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-02-2002, 09:43 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The square black box in this photo is the voltage reg. Ignore the way the wires are jumped. That plug should be plugged into it. These are dirt cheap at any parts store and if your new alt is not charging, I'll bet it is your regulater...10 bucks maybe.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-02-2002, 09:57 PM   #10
Longhorn Man
Post
oops, forgot the pic...
