Old 03-17-2004, 05:04 PM   #1
rickn
rickn's Avatar
body filler
getting ready to start the body work , thought i would get some input on bodyfiller /// "bondo" , duraglass , or lead , whats your thoughts
rickn is offline   Reply With Quote
Old 03-17-2004, 05:54 PM   #2
smokekiki
Mike
smokekiki's Avatar
Try this...http://67-72chevytrucks.com/vboard/s...threadid=90368 this is from the FAQ board.Also check on the paint board.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-17-2004, 11:54 PM   #3
walker
walker's Avatar
I just used evercoats new Rage filler. Went on very nice.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 03-18-2004, 02:16 AM   #4
krazy_texan
krazy_texan's Avatar
i use evercoat and have no complaints about it.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-18-2004, 03:53 AM   #5
Sweet72
Sweet72's Avatar
Evercoat works well.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-18-2004, 05:43 AM   #6
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
I'm using Evercoat Rage, and it's awesome!! It doesn't shrink like the Bondo brand, easy to sand, and barely get air bubbles to none in the Evercoat.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 03-18-2004, 08:16 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hmmm, never heard of this Evercoat, but I have been away from the paint booth of 11 years or so now.
Used properly, there is nothing at all wrong with plastic filler. The duraglass and all metal have there place, but in reality, there isn't too much use for them IMO.
Lead shouldn't be used. The lead will always put off gasses, and onc you paint tha truck, the gasses will hace no place to go, so it'll build up under the paint. Air bubbled under the paint is the result.
Old 03-18-2004, 08:53 AM   #8
cc_bob
I've always heard that Duraglass, should be the first coat over any welds. I know for sure that it sands like IRON , but if you use a rasp right before it is totally cured you can knock it down pretty quick. Bondo and other "LIGHT" fillers are typically for small blemishes and skim coats. If you are fixing small dings and such go with the lighter stuff, if you are putting in patch panels use Duraglass first (unless your ebfabman, check out his site, he does awesome work) if you have large dents, pound them out first.
Good luck
67 C10 396 stepside project
72 C20 402
72 K10 SWB (plow truck)
86 K20
cc_bob is offline   Reply With Quote
Old 03-18-2004, 11:41 AM   #9
kxmotox247
kxmotox247's Avatar
I've never heard that. I believe the factories still use lead in certain areas on the body. We've never had any problems with any of our lead work on our steel hotrods. I'n not calling bullsh!t, I just hadn't heard that before and it doesn't seem right.
kxmotox247 is offline   Reply With Quote
Old 03-18-2004, 04:33 PM   #10
gonebad2
Merciless Butcher
gonebad2's Avatar
The only filler I will use is rage. They also make the best glazing compound. A little higher priced than Bondo, but well worth the money. I bought a stinger gun for pulling dents. I'll tell you, that is the only wat to go. It speeds up the body work process considerably compared to the old slide hammer where you had to drill holes in the body. I have heard there are still some luxury cars that use lead. I would really like to learn that craft. You can really get some sharp crisp lines with lead.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 03-18-2004, 05:31 PM   #11
kxmotox247
kxmotox247's Avatar
Lead is really good for areas around door edges and jams where plastic will crack. On the older cars, lead was mostly used as a seam sealer from the factory.
Old 03-18-2004, 06:41 PM   #12
rickn
rickn's Avatar
i know how to lead, but just wondering if it was worth it , mainly for cab corners and rockers
http://rick.nicholson.home.insightbb.com
Old 03-19-2004, 11:02 AM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
I'm hoping you're not trying to fill rust holes, they need to be patched and welded.
For smoothing things out, the newer materials are easier to use than lead.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-19-2004, 12:13 PM   #14
rickn
rickn's Avatar
not filling in holes , going to put new corners and rockers on it
Old 03-19-2004, 01:37 PM   #15
Fred T
Cantankerous Geezer
Fred T's Avatar
Are you familiar with Martin SR. He has put together some good tips on bodywork.
http://www.camaros.net/cgi-bin/forum...=3;t=005647;p=
Fred
Old 03-20-2004, 02:14 AM   #16
Longhorn Man
The lead gassing off was what i was told in school when i was learing body work, and I have read it in a couple magizines too...if you're getting it right...keep on doing it. Sounds like you still know a lost art.
Old 03-20-2004, 04:02 AM   #17
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Put a vote in for Evercoat's Rage for me. The stuff is great although the only thing I used it for was to cover over the welds that filled my trim holes and a couple of very small dings.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-22-2004, 05:34 PM   #18
kxmotox247
kxmotox247's Avatar
I talked about the lead gassing off with my father this weekend. He's the one who does the lead work. The car in my avatar is the last one he built. Its a glass body but he made his own steel hood side panels. He used lead on the bottom reveal of the panels to avoid having plastic there which would crack out from the flex of the panel. He said he's never heard of lead gassing out but he did say that the most important thing (besides safety with lead) is to make sure you get the flux off of the panel otherwise the paint will not stick tot he surface. So maybe that's somewhat related to what you learned about leadwork.
He's going to be starting on a 40' Ford Coupe that we've had for years. It's going to require a significant amount of body work around the door jams since he's going to lengthen the doors. The car has lead on all of the fenders and I'm sure he's going to be using it this time too. He and I talked about using it as a seam sealer alternative in the rain gutter on my 68'. He thought it would work but his only concern is that it might be kind of hard to work the lead with the paddles down inside the gutter. If we use lead to fill it, I'll be sure to share pictures with everyone so they can see how we did it. Maybe it'll be a better alternative to the seam sealer that everyone else uses.
Old 03-22-2004, 06:25 PM   #19
lukecp
Formerly yellow72custom
lukecp's Avatar
Just make sure to put paint...not primer....over whatever plastic-based filler you use.
I learned this the hard way...put some bondo in one of my bedsides, primered over it, about 6 months later it started cracking pretty bad...looks like crap. I think this is because the mouisture seeped throught the primer and caused this.
BTW, i used Bondo brand bondo and it works OK.....$13 a gallon will fix alot of dents for cheap, but if i was trying to do a really nice job i would use it sparingly.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-22-2004, 11:01 PM   #20
Hooter
My other Love
Hooter's Avatar
I have used proform brand fillers on my vehicles, if mixed properly it works just fine for me, I have used actual bondo products before and found, like others said that it shrinks too much, DONT USE BONDO TO FILL RUST, REPLACE RUST WITH METAL
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
