03-18-2004, 11:15 AM | #1 |
Self-proclaimed LED man
Cold Air intake on 67-72??
Has anyone ever used anything like this? Would this work on a carburated engine or just efi? Kinda gives it a ricer appeal.
Cold air intake for 67-72 on ebay. |
03-18-2004, 11:19 AM | #2 |
I've thought about putting slots in the front of my hood for almost a "ram air" type of thing but don't want to cut up the front of the hood, and then also wasn't sure about running the hose. How much is this going for on Ebay? (I can't check right now, damn Proxy)
96 Bagged 2Door Tahoe 69 Blazer |
03-18-2004, 11:28 AM | #3 |
Keepin an eye out
Interesting...$300 opening bid. Probably took a couple hours to build.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
03-18-2004, 04:06 PM | #4 |
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
03-18-2004, 10:59 PM | #5 |
I've always wanted to build one, i don't like the looks for this one. I bet this one has some problem he can't fix and he's trying to unload it on ebay.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
03-18-2004, 11:25 PM | #6 |
cold air
You'll get more power from the cool air effect than the ram air boost at 60 MPH.
03-19-2004, 09:07 AM | #7 | |
Re: cold air
03-19-2004, 10:16 AM | #8 |
Why bother?Why?Why?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-19-2004, 10:25 AM | #9 | |
03-19-2004, 10:35 AM | #10 | |
Keepin an eye out
03-19-2004, 03:06 PM | #11 |
I think mine would have to look a little more like this. This is really ricer looking! Color match the tubes to the color of the truck, and it would look good.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
03-19-2004, 03:16 PM | #12 |
just get a K&N
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-19-2004, 03:37 PM | #13 |
Just get the BIGGest god darn K/N they make!
ps its K/N now
03-19-2004, 07:17 PM | #14 |
Check out Hot Rod or Car Craft Magazines. There is always an ad for a company that makes the carb box part. They are in Eastern Ontario Canada somewhere.
1968 Chevy - 292 with a powerglide |
03-19-2004, 07:37 PM | #15 | |
I love doing it topless
visit any ricer web site and you will find out why.
Mikey "If you can read this, thank a teacher; If you are reading it in English, thank a soldier." |
03-19-2004, 08:39 PM | #16 |
I've been thinking about building a cold air intake that connects to the cowl area. Anybody done anything like that before?
Toys: 72 K5 Blazer 74 Vette |
03-19-2004, 10:31 PM | #17 |
GM ONLY BABY!!!
Just get a cowl induction hood and make it functional. GM invented the "cold air intake" with the Cowl induction hood. I think it would also look better than extra crap to get in the way of a good looking engine compartment.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
03-19-2004, 10:44 PM | #18 |
cool air
The increase in HP at 200 mph from ram air is about 5%. At 60 mph it's probably around 1%. The difference in Hp between the engine sucking hot air from under the hood & sucking cooler air is substantial. It depends how cool the outside air is, but the gain would be more than 10%. Cooler air is denser thereby producing more power.
03-20-2004, 02:03 AM | #19 |
its all about the +6 inches
There is always this option...
03-20-2004, 03:41 AM | #20 |
yea cold air has more qxygen in it, there by better power, like 20+hp, the air under your hood can get up to 175 or even more under there, i like the ram air box, except u killed the lights, perhaps run the ducts to below the raditor, or in the bottom of the inner fenders, or the rad support, these are all open to the cold air. Just some ideas like to cowl hood also. Just my $0.02
'69 Chevy C10 400sb-350 crank 400 destroker!!! 377 2.02 dart pro1 alum.heads msd, holley db hooker pro-comps-3in exh. 3 spd. saginaw-3.73posi Flat Bed...want Reg bed...trades? |
03-20-2004, 09:50 AM | #21 |
Careful, they attack...
I would like to see tests on the one above. I don't think it will help all that much is hard numbers. The dryer hose has too many pleats, this make turbulance. You want a nice smooth path for the air to come in. Turbulant air is not any better than the air inside your engine compartment. If you took that air box and had tubes made for it, that would work. Not to mention, I don't see any air filter unless it's under the box. So you would suck in everything that was in front of you.
03-20-2004, 11:04 AM | #22 |
PROJECT 7DEUCE
Killler pic longhorn !!!!! I was thinking that if you used a thunderbolt style mount for the carb it would fit under the hood... BTW if chapter 2 has any input as to how that set up work's sure would like to hear it!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-21-2004, 04:26 AM | #23 |
I have no info, it is just a pic I pirated when I asked on here about Thunderbolt style cold air induction.
It is sweet...I've drooled over that rig for a couple years now. |
03-21-2004, 09:48 AM | #24 |
Cooler air is worth about 1 hp per every 10 degrees drop as a rule of thumb on the average NA motor, as zoomy says about 1% hp increase at 60 mph from ram air, but only if you put the inlet in a high pressure area. The major increase in any cold are intake is in the design, which allows more air in the engine(less restrictive) my 99 vette pic'd up about 12 rwhp with a cold air intake, which is common on the vettes based on the very restrictive factory intake design and element. Since it was on a dyno there was no ram air effect. As stated before this is a big topic on almost all FI car forums.
Mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E 1970 Chevy Impala 47,000 miles 2001 BMW 540i 6-speed 2002 Dodge Ram 1500 4x4 w/20's |
03-21-2004, 01:08 PM | #25 |
Old member
This is my set up.
Here is my K/N set up with cold air intake and a caddy box, with less than $15.00 in everything except filter. I bought two 4" couplers and one 4" ninty at Lowes and there you have it. I had the snorkel hose already from doing my 93 Sub.
