Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 03-18-2004, 08:39 PM   #1
Russell
Professional Grade
Russell's Avatar
Anyone own a early 80s Trans Am, or have the haynes manual?
Hey guys!
A buddy at school has his 402 powered Trans Am in the shop, and when he popped the hood I was just speechless at the mess.
Its gonna need to be completely rewired, and it needs the vaccume lines to be re run. There are open ports all over the place, and bare wires hanging out everywhere. No wonder the car runs like a pig... Its rad was completely dry, it doesn't have an overflow tank, so I'm taking the one from the 76 in tommorow for him, the power steering pump was nearly dry, the tranmission was nearly dry, and the engine oil is very very low. Overally the car is in pretty rough shape for having an engine that is only a year or so old... I told him to get exhaust on it ASAP or he'll burn or warp his valves as soon as he gets it warm and lets it cool off, so hopefully he is smart and gets some pipes on it sometime soon.
He isn't interested in the emissions equipment, just wants to run his hot air choke, and distributer advance.
He has a Q-Jet, and I'm fairly sure I know how it all hooks together, but I will be needing a wiring diagram to make sure that we get all the electrical done properly, along with getting all the vac stuff done right (if there is a difference for bigblocks)
Oh yeah, his brand new TH350 isn't shifting out of first either. The fluid (what little there was) was nice and red, with no metal particles in it. Is it the vac issues? He said that he had the ol' engine spinnin nearly 4500 rpm before it hit second bringing it in, and now it doesn't shift at all...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-18-2004, 08:55 PM   #2
1FaastC10
1FaastC10's Avatar
what year is it? the F-bodies changed body styles in 1982, and no Firebird was ever available with a 402.
1FaastC10 is offline   Reply With Quote
Old 03-18-2004, 09:00 PM   #3
Russell
Professional Grade
Russell's Avatar
It isn't the stock engine, it originally came with a 327. The car's body is a 1980, and the car's engine is a 1977
I'm not 100% sure it is a 402, but thats what the kid who owns it figures, it is a big block though.
Old 03-18-2004, 11:38 PM   #4
1FaastC10
1FaastC10's Avatar
327s havent been produced since 68. find out exactly what its got under the hood (read: get casting numbers) and go from there. the 402 was long gone by 77 too.
Old 03-18-2004, 11:42 PM   #5
Russell
Professional Grade
Russell's Avatar
Alright, I'll pull the casting number tommorow and figure out exactly what is under the hood once and for all
Old 03-19-2004, 01:54 AM   #6
Blue_71
Bloo
Blue_71's Avatar
i would say the shifting would be low fluid-- thats what it was on my 74
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-19-2004, 02:44 AM   #7
jimfulco
Vacuum modulator on the transmission is probably not hooked up or is defective. This causes high part-throttle shift points. Could the engine be an Olds 403? Some late-'70s Firebirds used them.
jimfulco is offline   Reply With Quote
Old 03-19-2004, 03:29 PM   #8
my68beatertruck
GOT JACK???
my68beatertruck's Avatar
a few points, if it's a trans am, i think it will have a factory shaker hood scoop. if it says 6.6 it will likely be a 403 Olds if its factory
4.9 is a 301 pontiac. if no numbers on the hood, anyones guess whats in there, everything fit in a f-body.
a few years back, early to mid 90's, i had little problem finding complete unmolested harnesses in the junk yards. i have personally changed at least 3 entire harnesses, and i forget how many engine bay/dash harnesses. not as difficult as you might think, and comes out much neater and cleaner looking than a patch job.
Good luck!!
68 C-10 250", 200R-4, LWB
04 F350 dually V-10, 6-spd
72 Cadillac Coupe DeVille
my68beatertruck is offline   Reply With Quote
Old 03-19-2004, 04:43 PM   #9
Russell
Professional Grade
Russell's Avatar
Did Pontiac make a bbc 400? The owner of the car insists thats what under the hood...
The school told him to take the car home today though, disturbing classes when we start it up, lol!
Old 03-19-2004, 06:28 PM   #10
boraxman
Keepin an eye out
boraxman's Avatar
Pontiac did have a 400 and it was all Pontiac. I had one in a '76 Trans Am....wish I still had that car!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-20-2004, 12:15 AM   #11
bigger=better
bigger=better's Avatar
All real pontiacs are big block engines, even the 326! late second gen. firebirds could be had with 350(Esprit cars), 301 turbo, 400, or 403 olds.
no chevy engines until 1982.
'68 GMC Sub 4X4 new project
'69 Pontiac GTO 20 year project
Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from.
bigger=better is offline   Reply With Quote
Old 03-20-2004, 03:47 AM   #12
Russell
Professional Grade
Russell's Avatar
Alright, ran the casting numbers, its a Pontiac 400 BBC, he took the car home though, so I'll just leave it at that then No longer something I can work on, so he can figure it all out himself :p
Old 03-20-2004, 05:49 PM   #13
1FaastC10
1FaastC10's Avatar
Russell, Pontiac never put BBC engines in ANY Firebird. they did however from time to time use the "Coprate 305 and 350", so it is possible to find a Chevy 305 or 350 under the hood of a 70-81 Firebird. if its a true Pontiac engine, that car should be one hell of a runner. one of my good friends has a '74 Formula 400 R/A car, and it flat screams.
Old 03-21-2004, 01:54 AM   #14
Russell
Professional Grade
Russell's Avatar
This thing screams too... You can hear it coming from miles away, and it has simply insane acceleration. Remember that this isn't a Firebird, its a Trans Am, and it does most definitly have a 400 BBC in it
Old 03-21-2004, 05:08 AM   #15
1FaastC10
1FaastC10's Avatar
FYI, there is no such thing as a 400 BBC, and if it is a Trans Am it is also a Firebird. Trans Am is the equivalent of Silverado... its a trim level. sometimes adds different suspension parts too.
Old 03-21-2004, 01:01 PM   #16
DOOBZ
BBC is short for Big Block Chevy, Maybe we could call it a BBP(Pontiac)
85 short, bags,4-link and sway bars
DOOBZ is offline   Reply With Quote
Old 03-21-2004, 05:28 PM   #17
1FaastC10
1FaastC10's Avatar
at which point it is still wrong. there is no big block, or small block Pontiac.
Old 03-21-2004, 05:29 PM   #18
Russell
Professional Grade
Russell's Avatar
Then what the heck does that car have in it then? He tells me it is a 77 engine from a Trans Am, and it is most certainly a big block engine. No doubt about it.
Old 03-21-2004, 06:23 PM   #19
1FaastC10
1FaastC10's Avatar
post some pics of it.
Old 03-21-2004, 06:30 PM   #20
Russell
Professional Grade
Russell's Avatar
Its gone now... It looked a lot like a 454, was bright orange. Had a 4 bbl Rochester on it, alternator on the right hand side, internally regulated.
He tells me he ran those casting numbers and it confirmed his 400 BB idea, but apparantly not then?
Old 03-21-2004, 06:31 PM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Like pointed out, you were calling it a BBC, it is just simply a Pontiac 400. The small cube engines were pretty much the same as the big cube engines on the outside.
The 305 and 350 engines (corperate...or chevy engines in reality) were never installed in Firebirds nor T/A or even Formulas, untill the 3rd generation cars were introduced in 1982. Before that, the Poncho cars were Poncho powered, even though the car had the same basic shell and underpinnings as a Camaro (A much better looking shel IMO.) they were Pontiac powered.
Old 03-21-2004, 06:41 PM   #22
Russell
Professional Grade
Russell's Avatar
Yeah, I said BBC which in my mind = big block lol
So pontiac's engines all looked like a chevy big block then?
Old 03-21-2004, 11:50 PM   #23
bigger=better
OK, Pontiac engines are Pontiac engines. The 301 326 350 389 400 421 428 & 455 engines are all from the same basic casting. The 301 and 326 are destoroked and therefore undersquare that's why they suck. The 301 was initialy produced for the Trans Am racing series (in '69 I believe) and subsequently failed. In '79 the 301 was turboed and this made it run decent, and was used in '80 and '81 also.
Pontiacs are of comparable dimesions to other big blocks that's why we consider them to be big blocks.
Pontiac's engine color has been a light blue color for many years.
In '80 and '81 the manual trans. cars got the "corporate" (read chevrolet) (crap) engine. From '82 on it was the "corporate" block only.
The Trans Am, Formula, and Esprit were trim levels on the firebird. Different suspension packages were options also, like the ws6 pakage-a suspension upgrade.
The Pontiac engine looks nothing like a Chevy!
If you people think the later model cars scream you should ride in a '70 455TA or even better a 73 or 74 SD455 TA OMFG talk about a wet dream!
IMO the Pontiacs have always outclassed their Chevy cousins.
That said, are there any more questions?
Not trying to be an ass I just know about Pontiacs.
Old 03-22-2004, 08:03 AM   #24
Longhorn Man
I've seen pleny of 4 speed 77 - 82 T/A's, but never a chevy powered one (Not stock anyways) they all had the 225 horse pontiac 400.or the 301 4 bbl. (The 2 bbl was with automatics while the 4 speeds got the 4 bbl)
The 301 was not part of the trans am racing efforts...pontiac never got that far in the plan. All it was was a last ditch effort to keep V-8 engines in there cars when the EPA was gettin strict. The 301 has very few parts that interchainge with teh rest of the Pontiac line up, it was supposed to be the next generation of pontiac engines, but in reality it was just a POS...and installed a turbo on it made it a ticking time bomb POS.
While I don't know Pontiacs, I have always studied the T/A...and I agree with you 125% on the 455 super duty...it is better than a wet dream, and much easier to clean up after too.
Old 03-22-2004, 11:48 AM   #25
Russell
Professional Grade
Russell's Avatar
ah, ok, I think I get it now. So it is infact a 400 then, just not a "big block" persay. Just looks like one. So maybe my buddy isn't a fool afterfall (and I am, woo!)
imo, they look a lot like chevy engines, especially when they are painted bright orange (its a rebuilt engine, so painted orange by whoever rebuilt it) -- Though that may explain why the HEI's vac canister is on the "wrong" side, and why some of the vac stuff is pretty odd, lol
I guess I just figured that all car manufacturers made a small and big block for their vehicles...
