Striker Bolt
Well the door slaming is starting to anoy me so i got to looking at the striker and it looks like its not far enough out. Question is can i use just a big washer in there to make the bolt come out farther so it doesnt rub on the door? Or is it more a problem with the door?
The door looks like its in the opening straight and it has no play when lifting on it.
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
Here is a pic, it looks worse then it actaully is. It was really tight when i tried to loosen it so i had to use a pipe wrench which cut it up a bit but most of it was just paint over spary so it makes it look bad all chewed up.
But what you really need to see is the red circled area. It has worn down from not being in far enough when shutting the door.
Looks to me that your door hinge bushings are worn out, not that the striker bolt is in too far.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
LED King
Those things are a booger to get out especially if the torx slot is stripped.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#5 | |
Garage Queen Material
#6 | |
Right turn Clyde
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#7 | |
Help section at the parts store has a hinge repair kits. If it's no slop then the striker needs to be moved down but I think your going to find it's hinges like 67-ss396 said.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
im betting that the door hinge is off a hair with play in it.sometimes its easier to have a buddy move the door up and down whole you look. a good vise grip will get the striker out if its stripped in the torx part. they sell tose too at help i believe
so many trucks so little time!!! |
yeah, I changed the bushings in my hinges, and know it closes easier now than when it came from the factory. I almost slam it too hard sometimes.
Dennis |
