03-19-2004, 11:42 AM | #1 |
Sell it before it's finished
Cab mount help.
I am installing my cab back on the frame this weekend. My cab mount kit does not have a diagram and I didn't pay close enough attention during disassembly. Can someone explain or post a picture of how the bushings and washers are placed? Also there are 2 metal sleeves with the kit. Do these go between the frame and floor at the front mount? If so , how do I install them? There is not an opening in thr front floor support to allow installation? Thanks for the help.
Brian |
03-19-2004, 12:44 PM | #2 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
do you have an LMC catologue? They have a diagram of the cab mounts...that may help ya...sorry I don't have an answer to your question tho...
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
03-19-2004, 01:44 PM | #3 |
user # 2756
Are you installing a poly kit? If so I have the directions that came with mine. If it is poly the sleve goes with the rad support, the one under the floor and under the gas tank would have reused the old sleeves. The bolt for the floor board is mounted inside the cab through the floor, should have a recess and hole.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-19-2004, 02:12 PM | #4 |
It is a poly kit. It came with the truck or I would be using rubber. Thanks for the info.
