Garage Queen Material
top speed?
what should my top speed be?
2.73 gears th350 tranny 6500rpm redline 28" tall rear tires 400hp+ |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Theoretically it will be 180, but there are TONS of other factors to consider. Like Brick wall aerodynamics, real road horsepower etc. ...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#3 | |
Live from Atlanta
Paul |
#4 | |
Live from Atlanta
...at @ 100 mph, you are probably going to go from WARP to WOBBLE!
Paul |
i've taken the old 305 up to about an inch past 85mph
i dont know about your truck but if i wind mine up real well on a down hill i can almost break the speed limit!
so many trucks so little time!!! |
#8 | |
5 day ban, learn to behave.
do you really expect us to know what your top speed is? I dont think that setup would ever see 130+mph even in ideal wind/altitude/tuning conditions
#10 | |
i know there are little programs around online to figure it out |
#11 | |
Right turn Clyde
![]() Take it easy on the truck, so you can get used it will be a lot different. They can and will get sideways even with an open differential on dry pavement. Wet pavement is just asking for it. I would rethink on setting the shift points sooo high with the transmission also. Running around and having to wind it up pretty tight 5500+ just so it will shift will get old and will give you more time to adjust to the truck again. That's just my impression though and trying to help you see what you may not see.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
i believe its only changing the WOT shift points
#13 |
yeller
Take it to Bonneville and find out.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#14 |
BAD BOW-Silverado XST
Not enough to keep up!!!
