G1 and G2 trans am question
i love this board for chevy talk so i thought i might run this one by and see if anyone knows about cars too.
been lookin' at buying a trans and i like the looks of the generation 1 ('70-'73) but i think that a TA with ttops ('77 and later) is cool too. i know you can easily swap parts from the 74-76 models and the 77-78 models, but do the body lines and hood match up on the 73 and 77 models...it looks like the front end might match up but i am really not sure about the back (especially the taillights)...obviously i would think that you would have to change the whole thing and probably some fabrication would be needed...but this would only work if the general body lines are the same. ________________________ 72 C20 Suburban (ochre) currently looking for 69-72 blazer ![]() ![]() |
If I'm not mistaken, the only changes to the exterior sheetmetal (roof & rear 1/4's) was the rear pillar from where the 1/4 panel meets the roof. It's easily detectable because pre-75's have the pillars & rear windshield stop @ about the trunk line. On 75 & later models, the rear windshield/glass actually rolls farther down into the pillar area. Other than possible minor trim differences, parts can interchange.... notice I didn't say 'parts easily interchange' .
I know of a couple of guys that used early (pre-73) camaro bodies & swapped to later (80-81 style) front clips & tailights. The tailights required replacing the entire taillight panel thats under the actual lenses. They also used the later model interior stuff as well (headliner, dash, door panels).
actually, the t-tops started in 75 or 76, they were the "hurst hatch" models. the hurst hatch is slightly smaller than a regular t-top. the models to look for are the 76-78 special edition cars with the trans am lettering in roman letters, gold tinted dash and steering wheel and hurst hatch t-tops. that is the special edition trans am. in 77 or 78 models look for the optional am-fm cb radio in the dash and 8-track player in the console.
hope that helps
i survived cancer and kidney stones, but my kids are killing me. |
thanks
thanks, guys...much appreciated.
gohogs216 |
its all about the +6 inches
Actually, the generation 1 would be before 70, and 70 - 81 would be 2nd gen. The front end parts would bolt up from 70 - 81, but I am not 100% sure on body lines and if it would look right.
