Got Horsepower?
front tire wear
what would cause the front tires to wear alot more in the middle than the outsides?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
My son, my joy.
I would guess that would indicate too much air pressure.
wayy too much air pressure the sidewalls of a radial should be bowed out a bit especially on the front they will look low at proper pressure
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Got Horsepower?
what should i have them at? they are 11.5 inch wide tires and right now they are at 30-32 psi.
its all about the +6 inches
11 inch wide tires, but what is the rim width?
If you have 8 or 9 inch rims, then that is the problem regardless of the tire pressure. If you have wide rims, you need to inflate them to what ever the side wall says. |
Got Horsepower?
they are 10 inch wide rims. and it looks like the entire tire is on the ground and the side walls are slightly bowed out.
Got Horsepower?
both front tires are at the same pressure but only the drivers side one is worn like that.
Must be them dang IDeeho roads. Tryin' t' miss them spuds fallin' offn' the tater truck! JK dude! That sounds strange man, my guess would have been over-inflation.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Got Horsepower?
i guess i will just put that tire on the back for a bit to even out the wear
When was your last allighnment? And did you have these tires then? Has it been lowered since your last alighnment?
