I've seen a few posts talking about using a 5-speed out of a full-size truck, but I haven't seen enough details to determine if I should consider it.
1). I think I read that the NV3500/4500 has integral bell housing and you would have to use the hydraulic clutch set-up. Is this true? 2). If so, how much trouble would that be? What parts would I have to take off the donor truck to make sure I got everything needed to do it right? 3). And, what are best years to get the tranny from?
Scott70Chevy '70 CST: LWB, Fleetside, black ext., black/gray int., 350-4bbl, 3-speed, 12 bolt 3.07, deep dish rallye wheels, NO RUST! |
From what I've seen on ebay, NV3500 does have integral bellhousing, NV4500 does not. Be careful cause not all NV4500's are the same - some were put in dodge trucks and have a different number of splines on the input shaft.
For years, look for about 91-up GM trucks. |
#3 | |
Bloo
nv4500 has a removable bell (my dads 94 K3500 has one)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Thanks for the help. Did the NV4500 come in 3/4 and 1 ton? Or do some 1/2 tons have them? Has anyone out there done a swap with one of them? If so, did you keep old bellhousing and clutch or swap in the hydraulic actuated clutch?
1/2 tons could have the NV4500, yes.
board member Huck has done a 5 speed swap, but I am not sure if it was the NV4500 or not. try to PM him.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
