Garage Queen Material
carb. accessories?
if i were to get this carb:
http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361 what all else am i gonna need to get it hooked up correctly? what else would i need to get for it so i could tune it and make sure its running the best it can |
#2 | |
Re: carb. accessories?
what about throttle brackets and things like that?
i'm not wanting to reuse any of my old ones. |
5-7 dropped 87 CC Dually
I would get Jegs Part# 720-9678 , 865-2418 & 720-1558.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...77&prmenbr=361 would any of those work? what else would i need for my kickdown cable? |
If your running a 700r4 you will want to get the 700r4 bracket for holleys. You can get them at advance auto, they should have a big book with all the parts in it, don't remember the part number but its basically a 700r4 bracket for the throttle and TV Cables. Bolts to the base of the carb through the back right carb stud/bolt.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
th350
#8 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
![]() ![]() Gchemist, I think, has the part number for the throttle bracket assembly.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
I never run a kick down on a HiPo motor. Thats what the shifter is for.
from expeirience, i know that manual shifting an auto trans is a bad idea.
http://store.summitracing.com/partde...rt=SUM%2DG1414 would be the part you need for a Holley carb. i would strongly suggest you rethink your choice of carbs. look at how often Tim posts about working on his... ![]() |
#11 | |
#12 | |
Wanna bet? ![]()
#13 |
well, i was thinking about getting one of the jet peformance qjets, but i would have to get an adapter plate for it also, which means lots more money. if i do anything, i'll buy a holley street avenger. would a 670 or 770 be better?
#14 |
so if i were to get all this stuff, i would be good to go?:
http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361 http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361 http://www.jegs.com/cgi-bin/ncommerc...40&prmenbr=361 510-34-160 http://www.jegs.com/cgi-bin/ncommerc...31&prmenbr=361 (just because i want it and its cheap) http://www.jegs.com/cgi-bin/ncommerc...37&prmenbr=361 |
#15 |
Yup. Don't forget the fual pressure gauge.
#16 |
okay, cause i get paid wendsday and will possibly order it then
