Old 03-20-2004, 05:28 PM   #1
RACING29
Anybody Build A Tubular Frame?
I was thinking about building a tubular frame for my truck and was wondering if anyone could give me any advise on some plans or anything that would help. Thanks DeWayne
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 03-21-2004, 02:49 AM   #2
PTS Kustoms
go to www.jimmeyerracing.com
PTS Kustoms is offline   Reply With Quote
Old 03-21-2004, 10:27 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's another option...
KRZ Custom
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-21-2004, 10:56 PM   #4
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
Well,
there are a lot of considerations when building a new chassis for your vehicle. There are numerous books available on chassis building, including race-style chassis, space-saver designs, tubular, clipped and others.
You need to write down everything you want from the new chassis. You ABSOLUTELY need to take exact measurements of every aspect of the original chassis, so that these can be transferred to the new chassis. When you have all the original specs, then you can modify them to suit your needs, whether this includes body droppin, shortening, lowering, or whatever. For example, will you still use the front and rear bumpers, if not, you can build the frame without provisions for them.
There are several comanies that make frames also, including Jim Meyer, Fat Man Fab, Art Morrison, Chris Alston and others. There are also clips for the front and rear available such as the aforementioned and also Competition Engineering, Jegs, and others.
Frame building is no easy task, but it can be done well with lots of planning and time. Don't cut ANY corners. Hope this info helps. Good luck!!!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 03-22-2004, 12:04 AM   #5
RACING29
Thanks!
