Old 03-20-2004, 10:04 PM   #1
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
tailgate skin tips?
OK, got my skin from MAR-K. Very nice quality. Anybody got any tips before I start.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 03-22-2004, 12:45 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I love my Mar-k tailgate skin. Which one did you get?
Here is mine.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-22-2004, 01:15 AM   #3
toytruck
toytruck's Avatar
I got the plain one. Do you spot weld it down the sides on the front of the panel?
Old 03-22-2004, 02:00 AM   #4
gchemist
gchemist's Avatar
Mine was not spot welded on the side. The body shop glued the edges. They used clamps while the glue dried. The spot welds are on the top. I don't remember if there are spot welds on the bottom. I can take pictures if you want some. Did you buy their tailgate handle relocator too? I like it. Pricey though.
Old 03-22-2004, 03:45 AM   #5
87 Shortwide
I used a Sir Micheals filler when I did my tailgate, and NO welding. I went down to my local GM lot and went to the body shop and picked up some of the GM body glue like they use to hold the door hinges on all the new cars. Layed a bead of that all the way around ant put my filler piece on, then I put weight on it and let it set for about 3 days. Absolutely no warping and it will NEVER come off.
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 03-22-2004, 12:22 PM   #6
toytruck
toytruck's Avatar
I'm going to have to check into this glue. Sounds like a much better way to do it. Yes, I did get the Mar-K handle relocator. Very nice and cheaper in the long run because I needed a new handle too.
