![]() Join Date: Apr 2003
exhaust manafold question
I just swapped out my single stock exhaust for a dual setup i got off another truck. I took my time and put it on right, but now there is a bad leak right around the manafolds where they meet the exhaust. Is there a gasket of some kind of forgot, or is there a trick that i didn't know about. Any help would be appreciated, i'm really wondering what is going on here.
thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
The exhaust manifolds that were set up with heat risers did not have an internal chamfer on them and the exhaust doughnuts will not seat very well against a flat surface. I am not sure if this is the situation that you have, but it is all that I can think of based on your description.
Jim |
Yeah, they are set up with heat risers, should i try red silicone, or is there something else?
Thanks David
Semi-Senior Member
Speaking of heat risers, is your truck set up the same as the one you took it off of? 67-68s had the riser on the left side, 69-70s had it on the right side, and 72 didn't use on at all. If your's isn't the same, it could be putting the pipe at a different anlge and not be able to seal.
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
The truck i put the exhaust on is a 69, the truck i took the exhaust off of is a 70, but i think it had a later model 350 in it. You might be on to something there, thanks 68 speedalert
This is what the bottom of one with a heat riser looks like
This is the heat riser and the gasket that goes between them.
On the other side of the heat riser you should have a little piece of pipe with the donut around it. A lot of people don't remember that little piece of pipe and the donut will blow out in time. GM used this little piece from the factory.
Semi-Senior Member
Good posts Dean!
Steve
