Old 03-21-2004, 09:09 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
Question What does it all mean????? ohhhhh the humanity! sbc 350 id help!
I know how to fix these motors but i don't know anything about how to ID them.
The 350 long block was Remand by FliteLine Motors of Fort Smith, Ark.
Tags say:
- tested on 6-10-99
- Purchased on 6-9-99
- bore 060
- Mains 020
- rods 020
- Oil press 58
- oil flow 32
- Amps 12
- Compression all eight at 210
My new 350 long block has these numbers on it:
On the block it has 14010207
on the heads it has 39998991
mortec.com says that the block is a 350 from years 80-85 and can be a 2 or 4 bolt main. Other sites tell me that this block was designed for passenger cars like the malibu or the camaro and that it was for an 80-84
I can tell that the Dip Stick is on the Passenger side of the block.
It came w/ a complete set of gaskets and an oil pump.
a set of solid metal exaust gaskets came w/ it as well but i don't think that they're gaskets, so then what are they?
i'm still trying to find out about the heads the only thing i've found so far is that they're from 1968-76 307-350 engines
what does chamber mean?
what does CFM mean?
you guys tell me what to put on this thing.
what do i need to get this running. Mind you I don't have alot of cash.
I know i want to put an edlebrock preformer intake and 600-650 CFM carb on it. I Just bought another 68 and it came w/ Ramhorn Exaust so for now i'll stick w/ that.
will put more on as i get it or think to ask
please as many replies as necessary!
If ya say something that needs explination please do so.
thanks, SSWJ
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-21-2004, 09:20 PM   #2
Blue_71
Bloo
Blue_71's Avatar
3998991....72-73...307/350......75cc chambers
hp= horsepower
chamber= the cylinder where the piston rides
cfm= size of the carburator (has to do with the air/fuel ratio it pulls)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-21-2004, 10:06 PM   #3
jamis
F.A.S.T. president
jamis's Avatar
CFM= cubic feet per minute, how flow is measured threw carbs, intakes, head ports...etc.
CC= A measure used to measure space, I cant remember how many ML there are in a CC, 100 or 200. Any way it mostly used to measure combustion chamber and piston volume......to figure compression ratio.
HP= horse power....measured as torgue X RPM '/. 5250
"The Dip Stick is on the Passenger side and it came w/ a complete set of gaskets and an oil pump and a set of solid metal what looks to be like exaust gaskets but they aren't gaskets, what are they? "
post a picture of the parts you want to ID, if you can.
jamis is offline   Reply With Quote
Old 03-21-2004, 11:07 PM   #4
whitesswj
Embrace the Redneck
whitesswj's Avatar
clairfication
post a picture of the parts you want to ID, if you can. [/B]
i haven't any parts to id except the block and heads, I'm just looking for the year of them and what i can an cannot put on them.
I was just stating that the Dipstick hole is on the passenger side.
thanks.
'01 Camaro
Old 03-21-2004, 11:26 PM   #5
whitesswj
Embrace the Redneck
whitesswj's Avatar
ttt
'01 Camaro
Old 03-21-2004, 11:53 PM   #6
bigjimzlll
bigjimzlll's Avatar
chambes is the combustion chamber size..its measured in cc's..its the cut out part of the bottom of the head where the valves and spark plugs are. 991 heads are run of the mill smog heads..nothing to write home about. The more cc's the chamber has..the less compression
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-22-2004, 01:33 AM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
There should be a date code on the block and heads. I believe it is the last digit. (D-19-8) would be april 19th 1968 or 1978. Just an example, if you find that code # post it on here.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-22-2004, 02:35 AM   #8
whitesswj
Embrace the Redneck
whitesswj's Avatar
the only thing i found on the block that resembles was h38 and directly below it was 509 those numbers were found on the rear of the motor right beside the driver freeze plug and then i found 207 under neath the other freeze plug on the rear and on the top of the rear part of the block behind the heads on the pass side was 141
on the heads i found the number above and then GM then below that was 70 and then somewhere else i found 866 and then on the pass if ound on the outside of the head stamped on the front of the head MH5132 and on the driver i found MH5148 thats all i've got maybe a few more. thanks sswj
'01 Camaro
Old 03-22-2004, 11:09 PM   #9
Southpa
Southpa's Avatar
Look on the front pass. side of the block for a small machined platform. On that platform is stamped the engine suffix code, usually a series of numbers followed by 2 or 3 letters. Look up the letters at this site:
http://nastyz28.com/sbchevy/sblock.html
and you can get more specific info on your engine block than Mortec can provide with the other number, ie. the raised casting on the back of the block. Hell, the number on mine spans a 10 yr. period.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
