Beep! Beep!
![]() Join Date: Nov 2003
i am puttin the stickers from LMC on the tailgate right now and i was wondering what the best method of application was
thanks for the quick responses 72afr
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
![]() Join Date: Feb 2001
Watched calvin do mine and I know he used a heat gun and it seems like they were wet but cant remember that for sure
Used a small piece of soft plastic to get the bubbles out. |
Beep! Beep!
thank you very much
I can call him tomorrow if you want me to
I can tell you mine are stuck good........... |
Beep! Beep!
if you wouldn't mind, that would be great
thanks again 72afr
Little late to call him tonight but will first thing in the morning.
It Is What It Is
72afr, get a squirt bottle with a little liquid soap and water, squirt the tailgate and the back of the letters before applying. The soapy water helps so that you can position the letter without it sticking. Use a plastic bondo spreader to smooth the letters and move the water from behind and remove bubbles. Then use a heat gun to dry. Hope this info helps.
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
Yep thats it..........just one thing that Calvin added was to make sure you had your fingers wet before you peel the backing off to keep them from sticking to your fingers. Take your time/careful.
More Cowbell....
If you use the heat gun, be careful. They WILL MELT if you get too close, too long.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
TOTY 2006
![]() Join Date: Dec 1999
I just tried windex on an aircleaner decal and it worked great!!
I was putting a 429 ThunderJet sticker on an aircleaner, and I sprayed the air cleaner with windex, then put the sticker on the cleaner, moved it around til it was perfect, then used a new plastic bondo spreader to get the fluid and air out. Once it dried, it looked perfect!!! I knew you could do this for regular decals, but I did not know that it would work on adheisive backed decals as well!! |
Beep! Beep!
wow thank you all for the responses
72afr
