Rear End trouble,
Hi all,
I may be looking to change out the rear end on my '84..............I took a right turn today under moderate acceleration and heard a loud scraping noise coming from the rear end. It only happened once but I would be willing to bet a outer axle bearing spun. The truck just feels "off" too.......or maybe 'loose" is a better word. This poor 10 bolt (8.5") has been through alot of stuff in it's time and the only reason I think it has held together is because I've used nothing but Mobil 1 in it. Yes...........there is a question in here somewhere! What would you do? Try to rebuild the little 10 bolt or step-up to a 12 bolt. I really want to use my factory wheels and can weld on spring perches if I need to. I hate the 2.73 rear end gear in there now and would also to lose the "peg-leg".............maybe a air-powered locker or the like. What would you do? |
BAD BOW-Silverado XST
Replace the 10 bolt with a 12 bolt and step up in gearing. Lose the peg leg with a Lock-Rite locker from www.powertrax.com
Thanks gchemist!
I, for one, don't want full-time locking because I drive on ice from time to time but would like something I can turn on and off. I have seen too many times where my truck would have been in the ditch if both wheels pulled. If I lived where you do I would buy a Powertrax in a second.........they have the best design by far. (In spite of the claim that they use Zytanium in the construction of their units=never heard of it) Keep the ideas and opinions coming..... Last edited by Mike76251; 03-22-2004 at 08:53 AM. |
91 SWB 383
i use a min spool and 3.42 gear now . in a 12 bolt
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
