COMING SOON...
What drop shocks are you using?
Looking for a good set, chime in with what you got.
Watch out for your cornhole !
![]() Join Date: Jun 2003
KYBs from Early Classic, nothing but smiles...
senior member
i went with belltech
69 GMC bagged |
Same as Tx Firefighter.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
![]() Join Date: Feb 2001
I have KYBs shocks on my truck...No problems...Then again the Circuit Rider isn't on the road yet.
KYBs.
Silence is golden, duct tape is silver. - Scott |
COMING SOON...
So, would I order the fronts according to the coil drop and not for the 2.5" spindle if I have a 4.5" total drop?
Also, are just the drop shocks enough for the rear, or are relocators needed? I'm looking at doing a 4 to 5" lowering at the rear. |
Iv'e got KYB's, 4" drop in rear. Get the shock relocaters other wise they will be about useless.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Member since 2000
COMING SOON...
Would it the ECE relocator kit work with rear leaf suspension?
I don't have leafs, but the impression I get is just flip the rear end and use shocks for a 4 -5" drop. Ask the folks at ECE, they'll talk to you.
