03-22-2004, 09:57 PM | #1 |
Happy to be here
WTB- NOS 73-80 trim
I'm looking for a complete set of NOS GM side molding for a 73-80 short fleet. I will consider pieces, but it must be in new condition....
PM or Email me at abcmusic@sbcglobal.net
03-22-2004, 10:42 PM | #2 |
Professional Grade
You gettin rid of the gold trim?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
03-22-2004, 10:46 PM | #3 |
Happy to be here
No I'm keeping it. There are a couple of pieces that need replacing due to minor damage. I tried the LMC stuff but it doesn't look like I want, so I'm trying to find a complete set of NOS GM trim to replace it all at once...
03-23-2004, 01:32 AM | #4 |
yeller
PM'd ya Ken...hurry up and check it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-23-2004, 01:36 AM | #5 |
If Ken doesn't buy it all.....I need some too.
03-25-2004, 12:51 AM | #6 |
Happy to be here
anyone?
04-01-2004, 11:31 AM | #7 |
Happy to be here
ttt
04-04-2004, 09:42 AM | #8 |
04-04-2004, 07:32 PM | #9 | |
04-05-2004, 08:01 PM | #10 |
Keeping this TTT
04-06-2004, 05:16 AM | #11 | |
Parts illustration book, or go to dealer they can pull up part numbers off thier computer Here is example of research for my 1980 345123 Rear cab Mld Center 345124 Rear cab Mld corner RH 345125 Rear cab Mld corner LH 347705 Dash emblem 364377 Door Handle trim - GM uses this number for L/R 364379 Door panel trim ring LH 364380 Door panel trim ring RH 461616 Dash plaque 466759 Aluminum panel -LH 466760 Aluminum panel -RH Last edited by Nvbowtie; 04-06-2004 at 05:45 AM. |
04-06-2004, 02:55 PM | #12 | |
No PN's & since everything is discontinued, that's as far as they go (w/o much effort to actually search). Thanks for the tips though.
04-06-2004, 03:39 PM | #13 |
Slots go on anything!
Fender
Rt mldg. upper-6260840 Lt. mldg upper -6260839 Rt. mldg. front-374295 Lt same part # Rt. lower mldg-6260842 Lt. lower mldg-6260841 "Cheyenne 10" nameplate 14016636 Door Rt upper mldg; yellow-463608 Lt. upper mldg yellow -463607 Rt. upper black-475544 Lt. upper black-475543 Rt. lower yellow-463612 Lt. lower yellow-463611 rt. lower black-475560 Lt. lower black-475559 Tailgate upper and lower-475535 I got these from the estimating system I use at work. I need to know the wheelbase measurements for long and short to sort the stuff from the bed moldings I found. That and I can't type, so those took forever. Not all of the moldings were showing both black and yellow, I put up what I could find. I also don't know which ones might be discontinued.
1974 Jimmy- 5.3/4L80e/NP241 |
04-06-2004, 08:58 PM | #14 |
Jonboy.... you 'da man.
The wheelbase is 117.5". I'm suprised they list them as black or yellow. I assumed they would be one color or the other & more than likely whatever color was available last.... yellow.
04-06-2004, 09:07 PM | #15 |
Gentleman Jim Driver
Most of these pieces are not discontinued, but the ones that are available are available only in black.
Ken - if you still need help with this, pm me. I just bought an NOS set at the swap meet in Portland this weekend. I have all the pieces and they are all really easy to get to if you want me to look at some numbers.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
04-06-2004, 09:29 PM | #16 | |
04-06-2004, 10:15 PM | #17 | |
yeller
04-06-2004, 11:14 PM | #18 |
117.5" is shortbed, correct? I will add the rest of them tomorrow.
04-07-2004, 12:14 AM | #19 |
Excellent. I can't thank you enough..... or can I? Your not too far away that I couldn't supply you w/a frothy beverage or 2 .
04-07-2004, 10:46 AM | #20 |
Bed Moldings-
Rt. upper w/o 117.5 wb-black-475550 Lt. " -475549 Rt. upper w/o 117.5 wb-yellow-463618 Lt. " -463617 Rt. Upper w/ 117.5 wb black-475548 Lt. " -475547 Rt. Upper w/117.5 wb yellow-463656 Lt " -463655 Rt. molding lower front w/o 117.5 wb black-475564 Lt. " -475563 Rt. molding lower front w/o 117.5 wb yellow-463624 Lt. " -463623 Rt. lower molding rear w/o 117.5 wb-black-475566 Lt. " -475565 Rt. lower molding rear w/o 117.5 wb yellow-463614 Lt. " -463613 Rt. front lower w/117.5-black-475562 Lt. " -475561 Rt. front lower w/ 117.5 yellow-463352 Lt. " -463351 Rt. rear lower w/117.5 black-475582 Lt. " -475581 Rt. rear lower w/117.5 yellow-463622 Lt. " -463621 Cab moldings behind door- black-6258145 yellow-463609 I think I got it covered there. Hopefully those are the right numbers, usually the estimating system is right on when it breaks down the options like that.
05-12-2004, 09:59 PM | #21 |
WTB NOS 78-80 Trim
I don't know if you are still looking, but I found this on eBay.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33654 Doug |
05-12-2004, 10:30 PM | #22 |
Happy to be here
Yep, I'm still looking. Thanks for the heads up...
05-12-2004, 10:34 PM | #23 | |
Happy to be here
05-12-2004, 11:46 PM | #24 |
I paid $200. It was an awesome find since the pieces you CAN get from GM are over $1000 if you're paying list. You can't get the lower rear pieces on the front fenders.
The set I got even included the upper and lower pieces around the grill and the drip rails. I was pretty stoked. Two people I was with at that swap meet had just paid the big bucks to GM. They weren't too happy to see me get that deal... |
05-13-2004, 10:59 PM | #25 | |
Happy to be here
There is supposed to be a swap meet here this weekend. If I can get my 77 rolling I may try to get by there... |
