Old 03-22-2004, 11:57 PM   #1
ScottH
ScottH's Avatar
Rear gear ratios - how low can I go?
I have a series 3 posi and was wondering what my options were should I decide to change ratios.
Any info is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 03-23-2004, 12:06 AM   #2
walker
walker's Avatar
With a series three you can go as low as 3.73, I believe. After that you need a series four.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 03-23-2004, 12:53 AM   #3
bigjimzlll
bigjimzlll's Avatar
you can go to 4.56 with thicker gears made for a 3 series
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-23-2004, 01:37 AM   #4
kwmech
With the correct case I believe you can go to a 5.38 ratio in a 12 bolt
Old 03-23-2004, 01:49 AM   #5
smitty62
smitty62's Avatar
Series 3---2:76 to 3:42
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 03-23-2004, 01:53 AM   #6
cdowns
cdowns's Avatar
that's only for stock gears ,richmond gear has them like was stated to 4:56 for the series 3 carrier and i'm sure there are other companys offering them as well
Old 03-23-2004, 02:38 AM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Cat Fuzz is offline   Reply With Quote
Old 03-23-2004, 11:28 AM   #8
smitty62
smitty62's Avatar
Believe you have to use spacers, which is not recommended by Randy's R&P--I'd stick with stock configuration.
Smitty
Old 03-23-2004, 11:31 AM   #9
cdowns
cdowns's Avatar
NO SPACERS REQUIRED THEY MAKE THE GEARS THICKER
Old 03-23-2004, 06:56 PM   #10
Vince M
Vince M's Avatar
There are spacers available that will allow a 4 series gear to fit in the 3 series carrier and as stated you can also purchase the thicker gears for the three series. Pretty much the same idea just a different approach.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-23-2004, 08:36 PM   #11
2low72
is there a way to check what the gear ratio is in the rear end without pulling the diff cover?
2low72 is offline   Reply With Quote
