Old 03-23-2004, 03:18 AM   #1
Tim Christian
Tim Christian's Avatar
What is the biggest tire and rim you can put on a 2wd Burb?
Please list rim size and backspace alone with tire size and what drop you have. I am looking at buying a set of 20's and want to get the correct back spacing. Thanks
Tim Christian is offline   Reply With Quote
Old 03-23-2004, 09:33 PM   #2
68plus4sub
68plus4sub's Avatar
I'm getting to the point of thinking what wheels and tires I should put on also. Sure would be nice to know what worked on other burbs with different combo's.
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 01-31-2008, 11:51 AM   #3
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: What is the biggest tire and rim you can put on a 2wd Burb?
Let's See Some Big Billets. Bigger The Better. Here's Ace's 72 With 18"
KevsClassics is offline   Reply With Quote
Old 01-31-2008, 01:59 PM   #4
89 crew
I'm sorry to hijack, but that is freaking gorgeous! Ok hijack done.
89 crew is offline   Reply With Quote
Old 01-31-2008, 02:18 PM   #5
slimbailess
slimbailess's Avatar
22x9 font and rear 285/35/22.. i think they are 5" backspace
slimbailess is offline   Reply With Quote
Old 01-31-2008, 09:57 PM   #6
suville
suville's Avatar
Just wanna follow this, same interest!
suville is offline   Reply With Quote
Old 01-31-2008, 09:59 PM   #7
MrGoodpliers
MrGoodpliers's Avatar
I had these wheels on mine, 18x8 front, 18x9.5 rear I think 4" bs front 4.5" bs rear. Early Classic airbags on rear. Whenever I would turn into a driveway and go through a little dip, the rears would rub on the wheeltubs due to body lean. I recently put rallys back on. Do like the look of the biggies, though. The thing to remember for 71-72s if you are doing bigs and littles is to have rear wheels with 1 inch more frontspace than the fronts so they will fill out the wheelwells the same amount.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-01-2008, 03:16 PM   #8
Frizzle Fry
Frizzle Fry's Avatar
305/40/22:
But if you are going with 20's and stock wheel wells I'd copy Gringoloco's specs:
Front: 20x8.5 5.25" backspacing 255/45-20
Rear: 20x10 5.5" backspacing 295/45-20
After he lost the stock wheel wells... But they worked with them in place:
Frizzle Fry is offline   Reply With Quote
Old 02-04-2008, 05:34 AM   #9
salvageit
22x9.5 with 5.75 backspacing 305/40r22 On the driver side the front slightly touches the lip of the fender when as the tire tucks in when I let the air out. the pic. is @ ride hight.
salvageit is offline   Reply With Quote
Old 02-04-2008, 03:42 PM   #10
19723DR
19723DR's Avatar
22x9 and a +20mm offset. Tires are 265/35/22. Drop spindles, air bags, c-notch kit and an adjustable track bar. I have a 1/4" clearance to the inner fenders in the front. I have full steering when aired out!
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 02-13-2008, 09:56 AM   #11
Tim Christian
Hey 19723DR, How much backspace is a 20mm offset?
Old 02-13-2008, 01:51 PM   #12
19723DR
19723DR's Avatar
I just looked and they are actually 9.5" wide. The backspace is 6" but I also have a 1/4" spacer in the rear. You might need a spacer in the rear too if you go very low. The front is perfect.
97 Z71 3 Door
Old 02-14-2008, 04:23 AM   #13
bad_turbo
turbo enthusiast
bad_turbo's Avatar
nice to see so many new suburban members!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-17-2008, 12:50 PM   #14
Rokcrln
Rokcrln's Avatar
You might have one more in a day or so, we wil see
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-20-2008, 09:05 AM   #15
68burb
I'v got three
68 chevy 1/2t 2wd 454-th400 '08 ltz 20's and air bags
68 gmc 3/4t 2wd 292/ 465 thinking of going pre runner on this one
and a 95 gmc 3/4t 350 4l60e 4x4 tow rig/ daily driver
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 02-22-2008, 08:32 AM   #16
wagonhoe
wagonhoe's Avatar
Tim,
To convert mm to inches, either multiply the mm by .03937 or divide by 25.4 (25.4mm = 1 inch)
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around
1968 C10 Suburban, 350cid, 700R4, bent frame
1968 C20 Suburban, no motor, trans or interior (SOLD!)
1953 Packard Ambulance
1992 Caprice wagon
wagonhoe is offline   Reply With Quote
Old 02-24-2008, 08:03 AM   #17
bigdiceman
I was thinking of putting a29/ 15 /R20 on the back of my 67 gmc (after tubs of course).Anyone know how big of a tire will fit with a tub??
bigdiceman is offline   Reply With Quote
Old 02-24-2008, 08:16 AM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
There are a lot of sick looking Burbs on this board...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
