Got Horsepower?
brake adjustment
how do i adjust my rear drum brakes?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Designated A-hole!
Easy, but long way is to brake while backing up. There should be a hole in the drum that will let you reach the adjuster with a screwdriver. Adjust them until the drum starts to scrub, then back of a little bit.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
![]() Join Date: Dec 2001
If yours isn't done already, punch out the adjusting hole. Turn the drum until the hole is at the bottom, and turn the adjusting wheel down with a flat screwdriver. You will hear a ticking as the teeth on the wheel turn. This is because of the tab that prevents the adjusting wheel from turning backwards. I usually adjust my drums until I feel a light drag when I spin it. If yours are too tight, you stick another screwdriver through the hole to pull up the tab that prevents the adjusting wheel from turning backwards, and turn the adjusting wheel up.
Hope that made sense. John
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Semi-Senior Member
Hard way, but I adjust the wheel with the drum off, sliding the drum on and turning the adjustment wheel until I feel the drum drag when putting it on. Make sure that the adjusting lever will aonly allow the wheel to turn one way. If you can turn it either direction with the lever on it the lever is too high or low on the wheel to self-adjust.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
It's a catastrophic success.
![]() Join Date: Jan 2003
If you hadnt all ready, you might want to pull the drums and inspect the shoes before you run them out make sure their not metal to metal
