Old 03-23-2004, 11:30 PM   #1
chevykevy
chevykevy's Avatar
Adding Power Steering on 68 Questions
I have read a few threads concering the addition of power steering to 67 and 68 Chevys without the dimple in the frame to allow the radius of a power gear box to fit . Some folks say that if I space out the gear box with bushing material or washers, 1/2 inch, that it will work just fine. Others however, say that I will cause a bad case of bump-steer. I thought that as long as I adjusted the pitman arm the necessary number of teeth to make up for the the 1/2 to the left movement, as well as set the toe with the collars on the inner and outer tie rods, that there wouldn't be a problem. Does anyone have any suggestions or experience with the problem, to shed light on it for me, before I invest time and money in the project?
chevykevy is offline   Reply With Quote
Old 03-26-2004, 04:20 PM   #2
gr8scott51
gr8scott51's Avatar
I thought only 67 didn't have the dimple. I converted my 68 with no problems. It was already dimpled. The dimple is easy. WES at Classic Heartbeat has a 'how to' in his panel buildup.
good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 03-31-2004, 02:29 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I just bolted my power steering gear box on my 68 tonight. Donor truck was a 72. I had to notch the bumper bracket a little, and trim the lip off of the lower rad support bracket (I think, if I remember right). Other than that, it bolted right up.
The 68 frame has the mounting holes "bumped out" about 1/2" or so from the rest of the frame, so the gear box does not bolt flat to the frame. The bump helps it to stand-off the frame.
67's may be different, but this is how my 68 is.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
